Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
WD passport won't let me open my files - Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
SOURCE: WD Passport Essential 160gb with PowerBook G4
The problem is that your powerbook G4 does not provide enough power to your 160gb passport HD. This does not happens to the new Macs with intel inside.
There are several ways to fix it:
1) Go to West Digital Website and buy a "Power Buster Cable USB" (that connect your 2 USB ports to your passport HD in order to provide more power). I think that it costs 10$. This is the link: http://www.wdc.com/en/products/accessories.asp?ProdID=170
2) The other solution is easier. If you have an external USB hard drive with two USB ports, or a DVD/CD burner with two usb ports, you can pug your passport in one of the ports while the other HD or DVD/CD burner is connected to you PowerBook. You will be able to see and use your q60gb Passport HD.
Posted on Oct 25, 2008
kim_cu
  • 70 Answers
SOURCE: can't load a 13 gig avi file onto wd drive with 90 gigs free
Typically this is because there aren't large enough fragments to load. Run defrag several times and try again. You might also run the cleanup program and remove any temporary files, temporary internet files and anything in your waste basket before you run defrag.
Please let me know how this turns out.
Posted on Nov 23, 2008
SOURCE: WD Passport will not accept transferred files anymore.
usb
not recognize
Posted on Dec 07, 2008
  • 7 Answers
SOURCE: wd passport file customizing
If you open the Computer directory and identify the drive letter for the WD Passport drive, right-click on the drive folder and select properties. The properties tool for the drive will open showing several tabs. Select the Customize tab and you will see a heading for "use this folder type as a template" with a drop down menu. Here you can select different categories for the folder and apply it to subdirectories also by checking the box below. This should give the folders more of a vista look! If you want to personalize further and add your own images to the folder icons you can also do this here. If you don't select the apply to subdirectories option you can manually apply different styles to different folders in subdirectories. If you don't like the way things have turned out you can also restore the default settings.
Hope this answers your question.
Have fun
Posted on Dec 08, 2008
  • 916 Answers
SOURCE: WD passport 320GB Can I use it as storage, not backup?
You can use it as storage if you would like. You can also delete files once they are put on the passport. When it is connected to the computer open my computer and it will be listed there. You can use it as storage by copying files into this way rather than syncing it. Syncing it could cause you to lose files.
Posted on Apr 29, 2009
My wd passport wont open the details and files ....it is there on devices and printers but wont open the files in it..my wd passport is wdbacy5000abk-01
What hapened to the drive before it stopped working, does it fell down? try to listen to drive very carefully, does it spinning ? are there any abnormal noises e.g click... or beeps ?
Feb 25, 2014 | Western Digital My Passport Essential...
Tip
Western Digitial Passport Sync Software
WARNING: Do not think that theyourWD Passport, using the WD Sync software, is a backup drive; it is NOT !
As per the documentation with this device:
"synchronization software is intended to synchronize the data from a computer to the drive (WD Passport) and SHOULD NOT be used as backup software. To use this software properly, we advise that you do not wipe or
erase the data from the internal hard drive (computer) and resynchronize, as this will cause the data that WD Sync stored to the Passport to be deleted."
This is why you are hearing so many people saying that they are deleting the WD Sync software, reformatting, and using the WC Passport as a true backup drive where you can actually see the files that you are backing up, rather
than a bunch of unrecognizable sync files that likely don't have all the files that you thought you "backed up".
on Jan 18, 2009 | Western Digital Passport WDXML800UE...
Permission reset
Login with Administrator account on Windows (Root account on Linux) connect the WD passport, access the files / change the permissions.
Nov 14, 2013 | Western Digital Computers & Internet
WD essential 1tb I cannot open the software on my laptop. A window pops up saying WD has encountered a problem & must close program, send or don't send option is all. How can I access my Passport? It...
Hi: That portable hard drive is USB 2.0 is the port on the laptop USB 2.0 can you use a memory stick to transfer files from the one lap top to the other lap top then on to the external drive.
Mar 16, 2011 | Western Digital WD My Passport Essential...
All my files say they are shortcuts that cant be opened and cant be found, the location given is toiofix.exe (E:) and the wd passport itself is on drive (F:) .. The WD passport itself , i am told by the...
This blog article is exactly what you need to read in order to fix it. As your external wd drive probably infected with virus. Note: to start with, do not format the drive immediately. Regards
Oct 14, 2010 | Western Digital Passport WDXML800UE...
Accidentally removed WD My Passport for Mac without ejecting first. All files are still there, but I get an error when trying to open them. How can I fix this. TONS of stuff I can't lose...
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 11, 2010 | Western Digital WD Passport 250GB Portable...
I forgot my password how can I open WD passport?
This one way for unlocking your WD passport but assume you will lost your data
Download wdsmartwareupdate here : http://www.wdc.com/wdproducts/wdsmartwareupdate/
Download instructions :
1- Locate you WD disk entry, click on Windows or Mac according to your operating system.
2 - Click on Download now link at the bottom and download the soft.
Unlock instructions :
1- extract the zip file you've downloaded en run the.exe.
2- select Continue to update and accept Licence Agreement.
3 - Next select Update Firmware
4- Check the check box "I understand ......" under Warning section, a button "drive erasure" will appear.
5- Click on drive erasur button
6- Wait until the end of the process and quit
7- Unplug/turn off the passport and plug it back in. Your WD passport is unlocked
Dec 16, 2009 | Western Digital Passport WDXML800UE...
Apr 29, 2009 | Western Digital Passport 320GB External...
My passport "removes" my files!
Jan 16, 2009 | Western Digital Passport WDXML800UE...
Wd passport file customizing
Have fun
Dec 06, 2008 | Western Digital Computers & Internet
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
454 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
