Question about Panasonic Room Air Conditioner CWXC104HU
I have a Panasonic 1200 BTU air conditioner, that is 6 years old. It is 'squeaking' pretty steadily. It still works well as far as putting out cool air. Is there a way for me to get this fixed?
  • Robert Moller
    Robert Moller May 11, 2010
    Can unit slide out from sleeve ? If so you can lube the fan motor.
    Novelist:
    Champion:
  • 246 Answers
The 'squeaking noise' you hear is pretty much 1 of 4 problems with the unit.
1) Most likely it's a fan motor where the bearings are going out (metal to metal is causing the squeaking). The 'fix' for this problem is to change the motor which will run around $150 if you call a repairman, maybe more depending on the motor. I've been told there are still mfc's who put motors in their units 'that can be oiled' and I'm not going to say that's not true - but I haven't seen a motor that can be oiled - in years. They (mfc's) just don't do it anymore - after all - 'we're in a throwaway society you know.
Speaking of which - it might be 'cost effective' for you to think about buying a new unit, i.e. the cost of a new unit over the cost of repairing what you have. If you spend the extra cash for a new unit - then everything is "new" especially the compressor which is the heart of any AC unit.
2) Sometimes 'compressors' will also squeak - again it's bearings that are causing the noise and if it's a compressor - then you are in big trouble and should 'seriously' start thinking about a new AC.
3) a third possibility but not very likely - and that is it could be something as simple as a fan blade/squirrel cage (the fan mtr turns a blade and usually a squirrel cage) hitting some other part of the AC in such a way where you think it's squeaking you are hearing. I doubt if this is the case but if you pull the unit and take the cover off and 'turn the unit on' you might be able to determine this (for sure) and make an adjustment/fix on the spot.
4) lastly ... here is something I've done in the past. If you have the unit out of the window and the cover off - take a look at the fan motor and see if it's possible to take a drill and drill a very small hole on each side of the motor where the bearings are encased. (Note: drill the hole 'on top' of the encasement) - Then you take a oil can/plastic bottle and try to get some oil down on the bearings. This is a long shot (having a place to drill a hole) but if you can get some oil down on the bearings (remember you have bearings on both ends of the motor) it will extend the life of the motor possibly for years.
Like I said - I've done this (successfully) in the past. The big problem is that some motors don't have the 'built up encasement of the bearings' and so it's not possible to drill anywhere.
good luck!
Posted on May 07, 2010
040463610
How large a space are you hoping to cool? One room? One LARGE room? One SMALL room? One floor of a two-story house? A whole four-story house?
What's your climate like where you live? Very hot, dry, year-round? Cool most of the year but two weeks of hot during the summer? Just a little too warm in summer? Blazing hot all summer, including nighttime?
How's the insulation in the building you want to cool? Is it a plain steel building with no insulation? Is it a trailer? Is it a frame house with 4" walls and R13 fiberglass insulation? An old frame house with no insulation? An adobe building? A timberframe house with 8" of polyisocyanurate foam insulation?
All these are important to know when you select an air conditioner.
For most of the USA, assuming a frame house with 4" of fiberglass insulation, a 10,000BTU air conditioner will cool one large room or two small rooms pretty well, or a 5,000BTU AC will do one medium-sized room. Different places, and different house designs, and different types & amounts of insulation, will all have a profound effect on how much AC you need/want.
Jul 25, 2014 | Goodman Heating & Cooling
Motor on a/c is turning slowly. this is a old unit. hasn't ran for 7 years. there are 2 removable ports on top of motor. does motor need oil or something?
Hi The air conditioner does not have any places. to put oil in, if the motor is running slow or slow to start then I would suggest you look at replacing it. Ross
Sep 14, 2013 | Shopnbc Frigidaire FRA25ESU2 25,000 BTU...
I have a LWHD1500ER. It runs fine, the fan works pretty well, it runs through it's cycles( on then turns cooler off then back after awhile.) but it isn't cooling, the air coming out is not very...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 28, 2011 | Heating & Cooling
How much area can 1hp of this brand can cool
the 'rule of thumb' is 1 ton of AC for every 600 sq feet of a well insulated space (400 sq ft if not well insulated)- for example if the space to be cooled is 1200 sq ft - and is well insulated - you would require a 2 HP unit. 1200 divided by 600 = 2
if the space was not well insulated - you would require a 3 HP unit. 1200 divided by 400 = 3
note; 1 ton of air conditioning - is sometimes referred to as 1 HP or 12000 Btu. Whether you call it 1 HP or 1 Ton or 12000 Btu - they all three mean exactly the same thing.
take this example - 2 tons of air conditioning can also be referred to as 2 HP or 24000 Btu.
fyi - it doesn't matter what 'brand' - they all work off the same principle.
hope this helps
Jun 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a Panasonic 1200 BTU air conditioner, that ...
The ball bearings in the fan motor is toast. Options: 1. Contact your dealer or Panasonic directly. This is a known problem and Panasonic will send you a new fan motor for free or at a reduced price, depending on the age of your unit. You will probably have to change it yourself, or call a tech to do it for you (about 1 hour of work).
2. Change the ball bearing(s) in the fan motor yourself. 1-2 hours of work if you are somewhat handy. Buy a CERAMIC bearing (Size 608, ZZ, Ceramic - the same size you use for a skateboard) @about 10 USD (7 EUR) in your local hardware store. You probably only have to change one bearing, the one on the "inside".
May 20, 2010 | Panasonic Room Air Conditioner CWXC104HU
Wont heat a 1,500 sqft one story home..air is cold by time gets to far end of home..gas pack 3 years old
One thing you can do is slow the blower down, this
will give you greater temperature rise and heat evenly.
The length of the home is what is needed.
Its possible that you need to have dampers installed in your ductwork or you need a booster fan installed
on the ductwork that feeds that side of the house.
My guess is that you need 80,000 btu heat output
to come close to heat the house. Since ductwork is
sized for cooling you would need 36,000 Btu Cooling
output. More information is needed
Feb 14, 2010 | Ruud UAMB Air Conditioner
My panasonic in wall air conditioner doesn't cool anymore --
Hi, if your 6 year old Aircon has not yet been re-charged eversince it was bought, then yes it's time for a refrigerant re-charge.
I hope it helps.
Jun 01, 2009 | Panasonic CW-XC243HU Air Conditioner
THERE'S NOT A PROBLEM I NEED YOUR OPINION
This EdgeStar 10,000 BTU portable air conditioner heats and cools for year round comfort and is recommended for room sizes up to 350 square feet. This slim and light superstar uses the latest technology to squeeze the most powerful cooling from the smallest possible package this 10,000 BTU portable air conditioner has a footprint of just over a square foot and is under 28andquot high! This portable air conditioner is the most powerful portable air conditioner in its class and size range and can bring down mid size rooms faster than competitor's models.
Dec 27, 2008 | EdgeStar Portable Air Conditioner Heater
Panasonic Room Air Conditioner CWXC104HU Logo
405 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
