Question about HP PSC 1610 All-In-One InkJet Printer
Printing Stalled with flashing exclamation light
LCD indicate it is printing when infact it is stalled with flashing exclamation light and power light. Will not turn off. Pull power plug then plug it back in the printer resumes in the aforementioned manner.
  • 79 Answers
Do a powerflee
1) unplug all cables including power cable.
2) press and hold the On/Off button on the printer for 20 seconds.
3) plug back the cables and try printing.
Posted on May 07, 2010
Why does exclamation point orange light flashing on HP Officejet 7110?
The lights on the front of the HP product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems.
For more read... HP Support document and HP Tech Support .
Thanks,
Jun 27, 2014 | HP OfficeJet Office Equipment & Supplies
The Power light and the Resume light blink.
Print media is jammed in the
device.
Remove all media from the output
tray. Locate and clear the jam. For
more information, see Clear a jam
in the device.
The device carriage has stalled.
• Open the top cover and
remove any obstructions
(such as jammed media).
• Press (Resume button) to
continue printing.
• If the error persists, turn the
device off, and then on again
Feb 10, 2014 | HP Officejet 7000 Wide Format Printer
The "on-off" light is flashing steadly... while
The flashing light could either indicate a cartridge problem or the printer carrier has stalled.
Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed. To do the hardware test, follow the steps below:
  1. Switch the printer off.
  2. Put one sheet of paper into the paper feeder.
  3. Press and hold the power button and the paper feed button for three seconds until the power light comes on.
  4. Release both buttons. After three seconds, the printer will start to print. You should obtain a page containing a series of horizontal color lines, and a thick black line below these. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not turn off the printer, it will keep on printing this page.
To check if you have a cartridge carrier stall, follow steps below:
  1. First unplug the printer.
  2. Move the cartridges to the left by hand. In order to do this, you need to grip the top of the carrier belt (a black/grey belt with cog-like teeth) and pull it towards the right-hand side of the printer.
  3. Once the cartridges have been moved across, you can clip them out.
  4. Try to print without the cartridges in the carrier.
  5. If you no longer have a carrier stall, put the cartridges back into the carrier and clip them into place.
Try to print a document to check if printer is working properly now.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sources: - Lights Flashing on the Printer - How to Perform the Hardware Test on the Lexmark X74/X75
Jun 25, 2011 | Lexmark X75 All-In-One InkJet Printer
How do you clear the print jobs so that you are not printing the same things over and over
How to Clear Out a Stalled Print Job In order to stop a stalled print job, perform the following steps in order:
  1. Stop the Print Spooling service.
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • At the command prompt, type net stop spooler and hit the Enter key.
  2. Delete the stalled print job.
    • Open My Computer.
    • Go to C:\Windows\system32\spool
      • Delete any files you find in this folder (but do not delete any folders!).
    • Go to C:\Windows\system32\spool\printers
  3. Restart the Print Spooling service.
    • Return to the command prompt used in step 1.
    • Type net start spooler and hit the Enter key.
Once you have restarted the Print Spooler, the jammed print job will be cleared from memory. Now you can go back and re-print all the jobs that were held up.
Feb 15, 2011 | HP Office Equipment & Supplies
Printer will not print. power light and feed light blink on & off
the power and feed lights blinking is the indicator for a (printer cartridge has stalled) problem sounds like there is a cartrage mis-installed or a peice has broken off and is tripping the sensor. In the first part of you problem you said you resolved a carteage problem that might lend a clue depending on what you actually did to resolve that issue could be the cover that you have to peel off when you install a cartridge and a peice got torn off good luck
Mar 26, 2009 | Lexmark Color JetPrinter Z32 InkJet
PRINTER CARTRIDGE STALLED
Is there someting stuck in the printer like a pencil or a keychain, something small that would allow paper to pass but also trigger a sensor in the printer as the printer can detect that paper is being passed unevenly.
Question: does it just say that the ink cartridge is stalled or does the cartarige really stall?
Feb 20, 2008 | Computers & Internet
Clean the rollers, and if the it stalls again just tap the off button and that should reset it and should cont. printing.
Nov 16, 2006 | HP PSC 1315 All-In-One InkJet Printer
Message Ink Cartridge stalled
the machine needs servicing, something is causing the carriage to stall
Nov 04, 2006 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1610 All-In-One InkJet Printer Logo
112 people viewed this question
Seeker5211
Seeker5211
