Question about Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour
Model EHF SA 8 Wall Mounted Water Cooler with low water preasure
Model EHF SA 8 Wall mounted water Cooler - water running very slowly with very little water preasure. Is there a filter inside this unit that needs to be replaced or should I look for some other problems?
2 Suggested Answers
  • 127 Answers
SOURCE: water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Posted on Oct 18, 2009
I have a 1966 Johnson 20 hp model fd-20c outboard motor. It has low power. The motor is mounted so low that the pee hole is submerged nunder water when running. Could this be the cause of my low power...
Try mounting it properly,cavitation plate 1/2 inch below bottom of boat.An old motor like that many things could cause a lack of power.
Sep 06, 2014 | Boating
Why is suction and discharge lines of Goodman WMC24-1A split ac system freezing up.?
Low on freon, dirty evap, dirty filter or maybe restricted at the metering device
Jul 20, 2014 | Goodman Heating & Cooling
Elkay water fountain, model# erpb2_8c,how do I take apart to replace water spout?
There are between two and four screws, probably 1/4' or 5/16' hex, on the underside of the cooler. Remove them. Make sure the water is shut. There should be a valve similar to those found under your bathroom or kitchen sink coming out of the wall where your cooler is mounted. Locate the plastic tubing that supplies water to the bubbler, (water spout), and press in the collet. The collet is a collar that slides back and releases the tubing. While pressing the collet, pull on the tubing. It should slide right out. Now you must remove the mounting nut, and viola! You can remove the bubbler.
Jul 18, 2014 | Home
Water from Elkay wall mount water cooler is coming out cloudy. I know it has air in system and i let water run for over 5 mins but water remains cloudy. Looing for solution
  • Check the water shut off valve is not open all of the way if not open shut off valve all of the way.
  • Check to see if the regulator / control valve is restricted with debris or not working properly. If so clean debris or replace the control valve.
  • Check the water inlet screen is for debris, clean or replace screen
  • If there is an external water filter, check to make sure it is not clogged.Check the income water line, if flexible, to make sure it is not kinked, is it is rework it to remove the kink.
    Dec 06, 2012 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    WATER COMING THROUG FRONT OF FUJITSU fan coil unit
    vent pipes are not sealed properly and condensation is building up and leaking out .
    Jun 10, 2017 | Fujitsu 12RLS Halycon Wall Mounted Air...
    My geberit in-wall toilet won't stop running, and there is no way to access any type of plumbing fixtures to fix. Please help me!
    Shut off main water supply
    shut off water value going to your wall mounted toilet.
    look under your apartment or the room ajoining the wall unit.
    look for hidden wall space above unit
    Nov 29, 2010 | Duravit 111335001 Geberit In Wall Carrier...
    Water pressure is low on the elkay fountain
    Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
    Elkay water cooler does not turn on
    You need to first check the circuit breaker for that wall outlet, and see if you short circuited it from water going behind the wall. if that is the case you need to reset it at the circuit box and then run a bead of clear silicone on the back of the water cooler to prevent water from dripping down the back .
    May 30, 2009 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Boiler
    this is a drain valve -like a water tap just close clockwise firmly -please advise me - there are some things you have to do now- please respond asap
    Oct 31, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
    Wall mounting emerson lc320em9 television
    I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
    What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
    Jerry G.
    Jun 28, 2008 | Televison & Video
    Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour Logo
    303 people viewed this question
    Top Elkay Plumbing Experts
    jdthefixer
    Steve Wood Plumbing...
    Level 1 Expert
    robert
    Are you an Elkay Plumbing Expert? Answer questions, earn points and help others
