I tried to reset the display on my lg w2442pa monitor. I went into the control panel and attempted to set it to the maximum setting like I always do. The following message appears now : RGB OUT OF RANGE 95.1 kHz / 60 Hz and i can't get it to do anything. Tried rebooting and it just stayed the same. Help!!!!!!!
  • dmmennie May 07, 2010
    Very helpful !!!! Thank you!!!! Got it working again
  • 2,427 Answers
You need to change the settings back..
  • turn on computer and keep pressing the F8 key..(as soon as u turn on keep pumping this key)
  • select safe mode from the menu
  • change your display settings
  • restart computer..
that should fix the problem..
Posted on May 07, 2010
Monitor problems
Have you tried to reset all your setting to default through your monitor? Sounds like an overscan issue, like the monitor is trying to display video past the actual size of the monitor so it raps around itself. You could try and lower the screen resolution on your desktop and see if it goes away as well...
Nov 04, 2013 | Computers & Internet
Lg flatron w2442pa buttons not working
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
EAY38422105 AIP 0178A LG EAY38422105 Power Supply Backlight Inverter
Jun 20, 2012 | LG W2442PA-SF 24" LCD Widescreen 16:9 VGA...
Good Day, I have an LG Flatron W2442PA. The screen keeps dimming, re-adjusting the brightness etc. Can you please tell me how to fix this?
Power capacitor problem or failing board in the monitor. Best solution is to get it checked out by a professional. I'm assuming you have already tried this monitor on another computer or laptop? If not, try that first, if it then works ok, check the DVI lead and the graphics card on the computer you are using it on
Jul 05, 2011 | LG W2442PA 24" wide LCD monitor, DVI,...
The display is shrinked vertcally in the centre of my LG 915 monitor. plz help me out. Thanks
Hi nasirallahdi ,
If your display is shrinked vertically , please follow the below steps :-
  1. Check the settings button on your monitor , when you press the button you have multiple options coming up which includes reset option.
  2. Go to the reset option and select ok , so that your monitor is reset.
  3. If this does not solve your problem then it could be because of a incorrect resolution being set in your desktop properties , in the settings tab.
  4. To change the resolution settings you need to go to the display settings by finding the option on the desktop via right click and you can try changing the resolution and see if things get ok.
  5. If still the problem persists , then it could be a hardware fault which you need to get repaired via the manufacturer's warranty limit , if it has expired you will be charged for it.
  6. Most probably the problem is with the incorrect settings in the monitor panel , and i believe after you reset your monitor via the monitor panel , things would be alright hopefully.
Hope this helps ...:)
May 10, 2011 | LG Flatron 915FT 19" CRT Monitor
My aspire screen is upside down and the picutures are also upside down. How can I fix it?
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Apr 02, 2011 | Computers & Internet
Not able to use full screen
This sounds like bad resolution is set on your computer. The LG 22" FLATRON monitor has a native resolution of 1680 x 1050. However, your video card may not support this so you can also try any other 16:10 resolution like 1440 x 900.
To change your resolution in Windows XP:
1. Access the Control Panel.
2. Choose "Display".
3. Click the "Settings" tab.
4. Under "Screen resolution" move the slider to a 16:10 resolution like 1680 x 1050 or 1440 x 900.
If you computer does not support higher resolutions, you may consider replacing your video card to take full advantage of your nice 22" Flatron monitor.
If I can further assist you, please let me know.
Regards,
KYTechnology
Mar 01, 2011 | LG 22" FLATRON LCD Monitor
I am using LCD monitor LG, my son changed some settings which i don't know, Presently, the monitor says Out of range 53.6KHZ / 60HZ. What is the problem and How to solve this problem and restoration of my...
He may have changed the display settings on the computer. He may have altered the refresh rate higher than the monitor can handle.
You can try start the computer in safe mode (F8 repeatedly on boot up, till the safe mode option comes up)
This will load basic video drivers, you should be able to check your settings now.
Windows xp / right click on desktop and your settings are there
OR control panel / display
Sep 04, 2010 | Samsung 510N 15" Flat Panel LCD Monitor
Unable to drive LG W22432S monitors in WindowsXP
Hi there.
Go to the control panel, select display, click on the settings tab and set the display to 1024 x 768 pixels, that should sort the problem out.
Post back if you need more help.
Good luck and thanks for using FixYa!!
May 14, 2009 | Computers & Internet
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
19 inch tft lcd monitor blurry
go to control panel click on display icon and then go to setting tab and there you will find screen resolution settings
Apr 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
