Symphonic WF2703 universal remote code
I need the universal remote code for a symphonic tv model WF2703
SOURCE: Remote - I need the
Code 3 CT-9854 on the front of the remote. Toshiba tube style TV.
Posted on Mar 10, 2008
SOURCE: universal cable company remote control codes
brighthouse remote code for panasonic amolifier to adjust volume
Posted on Mar 14, 2008
IrishDruid
  • 2712 Answers
SOURCE: tv codes
Apex -0156
Symphonic - 0171
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 08, 2008
SOURCE: philips universal remote codes for symphonics tv
One more 'lost code list' person. I have a philips SRU 2040/17 universal remote and a sanyo tv. 'code seach' doesnt work, i need the actual 3 or 4 digit code. HELP! my kid wants to watch cartoons and i cant turn the tv from video back to cable.
Posted on May 30, 2008
aprmaejun
  • 97 Answers
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 18, 2008
I'm trying to play my Xbox on a Symphonic Tv model
push the av/tv button in the tv panel.
May 03, 2013 | Televison & Video
Find code for symphonic tv remote
very few if any universal remotes will work on Symphonic which is also Funai and some other brands.
Look on Ebay or Google the model number of the set with the word remote, remember not a universal.
Mar 10, 2012 | Symphonic SC313D 13 in. TV/VCR Combo
I need a code to control a symphonic tv model wf203 using a vizio universal remote.
Hello
Setup codes for Symphonic TV with Vizio VU R8 Universal remote control are:
10180,
10171,
11913,
11904
OK.
Oct 09, 2011 | Televison & Video
My TV Symphonic model WF2703 needs a new remote control. where can I buy one?
go online and purchase from manufacturer directly
aftermarket remotes do not work for all functions properly
good luck
Mar 13, 2011 | Televison & Video
I have a Symphonic WF2703 TV with no remote. How can you access the external inputs without remote
you will have to access the menu-if you do not have a menu button-you can purchace a universal remote-try symphonic or funai codes
Sep 07, 2009 | Televison & Video
Philips universal remote codes for symphonics tv
try to ask a copy from the store where you bought the unit. or search in the internet. send me the model and ill help you search in the internet.
Dec 10, 2008 | Universal Remote Control Remote Control
Had a universal remote for my symphonic wf2703 tv my daughter tryed to change something with the remote now plays the dvd player ok turn it off all that comes up is a black screen with video on it the...
I had to clean the sensor area for the remote on the tv somehow got something on it. I wonder how, my little 4 yr old daughter had know idea how it got there lol.
Aug 01, 2008 | Televison & Video
Remote codes for Emerson Symphonic tv?
I have a symphonic tv and a emerson universal remote cannot find code anywhere for this tv???? anyone know what to do cheap tv
Dec 22, 2007 | Televison & Video
Symphonic model wf2703
Do you have "standby" power? In other words, does the set click or buzz when you try to power up using either the remote or the front panel?...accordianman
Oct 20, 2007 | Symphonic ST420FF 20" TV
Televison & Video Logo
197 people viewed this question
Top Televison & Video Experts
Electro Med Services...
