Question about Crown MT 1200 2-Channel Amplifier
Com-tech 800, 1 channel not working..
Hi, im about to buy a crown com-tech amplifier, 1 channel does not work.. My question would be, is this possibly a simple problem that can be fixed without too much expense. and what would be the best and the worst case of a situation like this. any kind of advise would be fantastic, thanks, dave..
  • dave_ral May 07, 2010
    Awsum, sounds like you know your stuff, i will go ahead and purchase the amp now. Thank you very much..dave
  • 2,427 Answers
Once a chanel doesnt work its usually a problem with the output circuit.. Worse case senerio is the output ic ,, which isnt expensive to fix.. If your getting a good price then buy it,, take it to a shop change the output ic and you'd be set..
Posted on May 07, 2010
HOW CAN I REPAIR CHANNEL ONE ON CROWN CE2000 IT IS NOT WORKING TWO WIRES BECAME IN CONTACT WITH EACH OTHER
The power amplifier section should be troubleshoot for shorted output IC or transistor. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 21, 2015 | Crown CE2000 2-Channel Amplifier
Crown macro tech 3600VZ AMPLIFIER
Haven't found one yet tho i'm wondering... what issue/problem are you having with the amp ?
Robert
Sep 14, 2008 | Crown MA-5002VZ 2-Channel Amplifier
Crown CE1000 amps, 1 dead channel - Can I diagnose via RJ-45?
Before asuming it is the power transistors check the power on relay first as mine had the same proble and it was because of the Relay that did not switch on the one channel or amp (remember this is a power amp and consist of two mono amps)
Nov 07, 2009 | Crown CE1000 2-Channel Amplifier
Hi - trying to repair a CE 2000 crown amp. need parts R 33 (crown did have stock) R 36 crown said they dont see it in their list also LM4701T crown also said they dont know what that part is. i have...
I have a working CE2000, I might be able to help you identify the value of the parts....please send me pictures of the part location and indicate with an arrow.
yadsyon@yahoo.com
Aug 17, 2009 | Crown CE2000 2-Channel Amplifier
I have Crown ce2000,it turns off after a short period then on then off ect.
Hi...
IF all the outputs are connected right and it still does that..Take it to a tech..You have bad output transistors
Jun 27, 2009 | Crown CE2000 2-Channel Amplifier
I have a Crown CE1000 power amplifier. I turned it on the other day and I seen a bright flash inside of it. Now the fault lights are blinking and it won't work. Is there something that I can look for or is...
Unfortunately Crown amps are not the easiest to repair as they utilize multiple levels of amplification. Since you saw a flash, a resistor probable smoked, I would recommend that you bring this to an authorized service center.
Dan
Mar 17, 2009 | Crown CE1000 2-Channel Amplifier
Fault lights
I'm not sure what you mean when you say the channel 2 does not work in bridge mode. Bridge mode effectively turns the amp into a mono amp, thus there is no channel 1 or 2. The fans will only turn on when the heat is high enough, so that is not a problem. Please describe what you perceive as the problem with these and I'll try to help.
Thanks,
Dan
Nov 04, 2008 | Crown CE1000 2-Channel Amplifier
Crown com-tech 2 channel 400
One channel has failed and is in need of repair. There are some transistors inside that are "noisy" and sending signals down the line. This is a bit tricky to find, but a service shop that does audio repairs should be able to fix this. Figure about $15-$45 for parts depending upon what circuits are effected.
Dan
Aug 29, 2008 | Audio Players & Recorders
Crown CE1000
Cuold be the final power amp ic. Might be imput transistors to that channel. Its possible to have a cold solder joint on pcb.
Look close at board with good light and a mag. glass to see if any foggy looking joints and heat up with soldering iron then dab with fresh solder.
Good Luck
BigRED
Oct 20, 2007 | Crown CE1000 2-Channel Amplifier
Crown MT 1200 2-Channel Amplifier Logo
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
