Question about GE JBP80 Electric Kitchen Range
None of the top stove or oven elements work. Control lights come on but nothing is heating up at all. (GE JBP80)
    President:
  • 949 Answers
The control is operated by 120 volts and the heating elements work off of 240 volts.
The most logical reason for your not heating (if there is none of the burners working) would be that one of the sides of the circuit is broken. Most likely this loss has occurred at the circuit breaker, try turning the breaker off completely and back on.
If this does not resolve the problem then the power loss may be a broken wire inside the range.
It is best if someone knowledgeable in electricity with a good meter does the testing beyond the breaker or fuse in the home.
Posted on May 07, 2010
None of the elements work, stove top or oven, stovetop light 'surface heating' will come on but nothing heats. Oven light on panel doesn't turn on but light in oven is off unless both dials are on or a...
Remove the panel on the top of the back of the stove - check for grease residue on connectors plugged into circuit board - clean connectors and circuit board with electrical contact cleaner - reassemble and test for correct operation. The oven vent at the rear of stove sometimes leaks grease filled vapors into the area of the control circuit board.causing bad or intermittent electrical connections to oven temp sensors and front controls on the oven.
Dec 22, 2017 | Kitchen Ranges
My ge range has quit working. First the stove top (coils) failed to heat up (all at once); then about a week later the broiler coil failed to heat up shortly followed by the entire oven. The 'on' light...
The stove top is internally wired separately from the oven. Check that you don't have a faulty circuit breaker in your breaker panel. The oven is 240V which has two breakers ganged together. If only one side trips you can loose power to the heating elements but still have power to the control board (to light up ON).
Jun 23, 2010 | Kitchen Ranges
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Feb 20, 2009 | GE Kitchen Ranges
Oven will not heat
Although I am not familiar with this oven, living in the u/k, I would say that without any doubt the oven element(s) have failed, more so if the fan is working, so I would have hesitation that you replace the suspect element (s)..
Plz let me know how you get on.Thanks.
Jan 03, 2009 | GE JKP15 Electric Single Oven
Oven not working
This is either a faulty display panel, or a short inside the oven that is causing the panel malfunctioning.
The wirings, elements (both), thermostat contacts inside the oven must be checked for an eventual short. If there is none, replace the control assembly.
You find parts and diagrams here, just enter the correct model number.
Dec 20, 2008 | GE JBP80 Electric Kitchen Range
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
GE JBP80 Electric Kitchen Range Logo
154 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
