Question about Epson EMP-S1H Multimedia Projector
Shadow developing while slide showing in powerpoint through epson projector shadow developing.what is the problem
  • Andysoundz Apr 14, 2008
    Have a large green blob in the background fills most of the screen
  • 563 Answers
Hi there
If the shadow is always in the same place you will have to get one of the LCD's replaced.
It is the most common problem a LCD causes on a Projector.
Posted on Mar 27, 2008
SOURCE:
How to fix the shadow in my projector (red and green color) right and left side ..
Read the operating manual and recalibrate the projector as per in the instructions there.
Mar 21, 2015 | Epson PowerLite 1945W Multimedia Projector
Cannot get my projector remote to change the slide on my powerpoint,
I didnt think the projector was designed to run presentations without a pc to drive the display.
how are you loading the information?
May 28, 2014 | Epson EX30 LCD Projector
How do I forward the slides of a powerpoint presentation using the remote?
Make sure that you connect a cable (usually the USB cable is supplied with the projector ) from the computer to the projector. Once communication is established, normal PPT slide advancing is done by pressing the up/down arrow keys (depending on the remote control layout)
Dec 18, 2013 | Epson Projector Remote Controller...
When I turn on the lamp with no tray mounted, the light shines through and shows a shadow of the slide lift arm on the screen. The tray does not properly mount on the projector and the For and Rev...
You are describing, among other things, a timing problem with the projector. That is why the light projects with no slide in the gate and the tray does not properly mount. This could have been caused by a slide jam, which "broke" the re-settable emergency clutch. To check (and re-set the emergency clutch), plug the projector in, turn it on and push & hold the reverse cycle button on the projector for a couple of cycles. If it fixes your problem - great!! Otherwise you need to contact an authorized repair dealer for repair.
Sep 10, 2010 | Kodak Carousel 4400 Slide Projector
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
Powerpoint video won't play on screen
you can try changing your overlay settings. works with some formats. or you could use the projector as main display (toggle through fn+LCD/CRT)
Feb 10, 2009 | Epson PowerLite 50c Multimedia Projector
Epson projector from computer & powerpoint
You need a wireless presentation remote that has a transmitter that plugs in to the back of the computer. This can be used to advance the slides. Make sure you get one that states the distance you need.
Let me know if that helps.
-Jeff
Aug 23, 2008 | Epson - PowerLite S1+ Multimedia Projector
Growing Blue Shadow
Hi, please try to replace the cable, try another input source and reseat or replace the bulb . If issue still present upon doing those steps you may need to call epson tech. support at 562-276-1300 so that they can verify whether your projector is under warranty or not and give some great option regarding your projector.
Tirzo
Jun 05, 2008 | Epson EMP-740 Multimedia Projector
Picture off and shadow of back images.
Hi Grim159
I've had this once on a Epson Projector and the only way I could this right was by replacing the Mainboard.
Hope this is of help.
Apr 22, 2008 | Philips ProScreen 4600 Impact Multimedia...
LCD projector has a 'shadow' in the green color
This is a Mainbord problem , the lcd would have shown blotches on your imagr rather than a shadow effect.
Apr 19, 2008 | Office Equipment & Supplies
Epson EMP-S1H Multimedia Projector Logo
1,331 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
