Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Lamp Light flashes, possible replacement of lamp needed?
Need to know how to take it off to be tested and where it is located?
  • 175 Answers
There should be an acess panel on the back and just replace it they cant be checked if the lamp light comes on is gone
Posted on May 07, 2010
I replaced the projection lamp and the light flashed red 3 times after researching i found it was the projection door now the light just flashes red non stop
There are usually several micro switches (little metal levers) inside the projection tv - most commonly by the lamp assembly and behind the lamp door.
It's possible either:
a) the lamp is not fully seated into position - ensure the lamp assembly is locked into position and that all screws have been secured, which will correctly close the micro switch.
b) the lamp door is slightly misaligned - ensure the door is aligned properly (do not force it) and all screws MUST be secured into place, which will correctly close the micro switch.
If the above items are in their correct positions, then you may need to test the 'continuity' of the switches (open & closed) using a multimeter, to determine whether you many have a faulty micro switch.
Hope this helps..
Oct 31, 2011 | Sony KDF-50E2000 50" HDTV
Tv does not swich on. The red led light plinks 5 times.
5 flashes, bad lamp and/or lamp driver
4 flashes, bad or stuck fan
There is a chance that the bulbs are not bad, but you will need a small fan to test this. Place a small fan blowing directly behind the set and run it for several minuts before turning the set on. This may help clear the code and allow you to watch tv if not then your lamp or driver has gone bad and needs replaced.
Jul 02, 2011 | Sony Bravia KDL40HX800 40 in. LCD 3D HDTV
Replaced lamp. Green standby flashes 50 times, then shuts down
hello when you replace the lamps make sure you fitted the lamp securely and make sure the lamps cover fitted securely aswell
shaun
Dec 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony kf50wef610-television-replaced lamp about 4 months ago- now will not turn on - green light flashes 6 times- red light flashes 5 times once- then flashes 6 times with 4 second pause between --I am...
I believe the 5 flash error is for the lamp thermostat. It is located (I believe) on the right side of the lamp housing if you were looking from front. It is very small black square with white and gray wires covered in black sheeth. The only way to replace it is from the rear. you probobly need to do a thorough cleaning in there and thats why you've had the lamp, and thermo fail. Remember not to touch the lens of the lamp when working on it.
Jun 20, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony xl-2100u lamp
Refer to your owners manual on lamp replacement. Remove the old lamp and look at it. If it looks "blown" (like a flashbulb) then it is defenitely defective.
May 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Hi there
turn set on with lamp in and lamp cover also,and after tryin to tur on ,red ligh its going to start flashing a segment of times.
Let me know how many times is blinling?
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony xl-2100u lamp
you cant test the lamp the only way for sure to know is if the lamp exploded and you can tell that by looking down inside the lamp, yes there are other things like ballest and engine lamp, sony also has a recall on some of the sets, however all that info is at work so i don't know if this set is one of them, contact me on Monday and i can tell you more.
Jan 19, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Lights flashing and no piture or sound
I had the same problem a little over a year ago. It was the lamp. It needed to be replaced. I hope you have the extended warranty.
Jan 08, 2008 | Hitachi 50V720 Television
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
