Question about Sony RDR-GX7 DVD Recorder
Formats maxell discs,not sonys, then records less than2 mins.and reads dirty disc.. disc style cleaners,unplugging unit for days does nothing to help.store bought movies play perfect.
    Scholar:
  • 104 Answers
What you can do is open the Player. You will see a DVD drive in there (same type used in Computers) You can replace it with another IDE DVD writer. This solved many of my client's problems.
I always keep a few IDE DVD roms, and writers handy in my shop. It is the simplest, and cheapest fix.
Hope it helps.
Posted on May 07, 2010
Can i use any type of blank cd format i.e. MAXELL,TDK,SONY cd/cdr/cdrw. On a TASCAM CD-RW5000 or Do it just take the DIGITAL AUDIO/COMSUMER TYPE ?
What does the instruction manual say about what to use?
Personally I buy Taiyo Yuden and have never had a problem. In Radio we used a lot of CDRW900 units and they used them many times a day using standard data discs. Name brand discs like Maxell and the rest are there for profit- they don't make discs so they do not regulate the quality. Go to supemediastore.com and read up on media quality and you will end up with what I use.
Aug 13, 2012 | Audio Players & Recorders
My RDR-GX300 Stopped loading & formatting blank discs
either a dirty optical pickup or a a bad optical pickup in the unit=pretty much has to be one or the other
Apr 07, 2012 | Sony RDR-GX300 DVD Recorder
I recently received MAXELL DVD-R dvds as a gift. I have not been able to get these blank dvds to load so that I can record on them. I have recorded many SONY DVD+RW without a problem? I noticed that...
From looking over the manual they should work in your dvd recorder. The fact that they are reformatted might be the problem. The recorder needs to formate the discs before it can use them. Try having the recorder reformat the discs before you try to record to them see if that helps at all. From the reading of customer reviews I have looked over, it seems like the DVD+R 's are easier to work with overall. If formatting them again does not work I might go out and prchase DVD's you know that work and use these for back up or burning data or videos from a computer instead.
Good Luck.
Apr 30, 2011 | Toshiba DVR620 DVD Recorder/VCR
I put in a new disc to record and ( and get "Recording error, can not record on this disc." E 4 54039000. Seems like it doesn' want to format as usual. This just started about a 2 weeks...
E4 error code means that the disc isn't being read, because the unit is dirty or the optical eye is going out .You have to get a cleaning kit and then proceed.
you may try this:
unplug from wall, wait 15 minutes, plug back in, and reset the clock,
or
The disc must be DVD-R with an R4.7 under the logo and they MUST be 4X or 8X specific .... the cannot be 1X - 8X or 1X - 16X or note up to 16X .... the disc box must state 4X or 8X ONLY .... and yes they are hard to find for sure
Mar 16, 2011 | Toshiba DR570 DVD Recorder
Hi my traxdata cd900 recorder has just developed a problem. Ive been using maxell cdr's most were fine but lately:- a) optical failure error occasionally occurs b) will happily record approx 15 mins...
First to confirm if its a transport problem play a CD from track 1 to the last. If it is not getting stuck and smoothly plays till the end -- transport is OK. The same laser unit which reads the disc also writes. But when it writes the laser intensity is several times higher and the unit runs very hot. And old unit will start to misbehave due to the heat. TIME FOR REPLACING THE DRIVE UNIT.
Mar 10, 2011 | Audio Players & Recorders
My Samsung DVDR120 will not accept any new DVD-RW discs. I have tried Maxell, Memorex and SONY. They all either freeze at 85% initialization or formatting, or spit out saying system error. The machine is 4...
This is a common fault and usualy caused by the DVD drive going faulty, The Lazer changes angle as it records across the disc and at about 80% there is a change point.
I suggest putting a cleaner DVD through the unit before you try anything else as a bit of dust can cause that problem. If that doesn't fix it than you may need to change the DVD loader unit as a whole or as you suggested by a new modern unit with even more features.
Jul 16, 2010 | Samsung DVDR120 DVD Recorder
Incorrect disc
Some machines work with -R some with +R. My suggestion is to try a + or - R RW which is rewritable. If you screw it up, no harm done because you can always reformat it and start over again. Don't forget to format the rewritable at the start.
Sep 19, 2009 | Toshiba D-VR4 DVD Recorder/VCR
I have an ilo dvd ro4 and when I put a disc in it says invalid disc
Laser is either dirty or starting to wear out.It may also not be a compatible disc,not all brands of discs work in this model.The unit records on R+Rw+ discs 4x speed or slower.Variable speed discs1x-16x will also work.
Most of the time it is just a dirty laser that can read the disc,to clean laser use a commercial laser cleaning disc,Phillips and Maxell work well in this model.Put a drop of rubbing alcohol on cleaning brushes.
Jul 06, 2009 | iLO DVDR05 DVD Recorder
DVD Recorder will not format blank DVDs
I kept formatting DVD's until I got the unit to work. Mainly, it was some DVD's I had earlier problems formatting. I tried two new DVD's (Maxell DVD-RW) and they worked thus far. I truly think the unit needs to be taken to authorized service center for evaluation or minor maintenance. My suggestion is to verify the DVD's will work with unit. Try to use better quality ones like TDK or Maxell. Thanks for responding to my problem. If I have others, I will contact you.
Feb 09, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Problems with dvd reading
I HAD THE SAME PROBLEM WITH MY LG DVD RECORDER NOT EXCEPTING CERTAIN RECORDABLE DISCS . NO GUARANEES BUT TRY GOING TO YOUR SETUP MENU AND RE-SET THE ORIGINAL FACTORY SETTINGS FOR THE RECORDER THEN PUT A DVD CLEANER DISC IN YOUR RECORDER TAKES ABOUT TWO MINS TO CLEAN UNIT THEN TRY A BRAND THAT DOES WORK IN YOUR RECORDER OTHER THAN VERBATIM OR MAXEL . RECORD SOMETHING THEN EJECT IT . NOW TRY ONE OF YOUR MAXEL OR VIBATIM DISCS AND SEE IF IT WILL READ THIS TIME FOR RECORDING . GOOD LUCK . BEST REGARDS , blc7772001
Jul 21, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Sony RDR-GX7 DVD Recorder Logo
283 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
