Question about Creative Labs Zen Micro MP3 Player
Creative remain in recovery mode.
Once the battery is fully charged remain in recovery mode and that is. Also I listen to a sound like a click when I touch the middle of the MP3. I heard it is a bad hard disk problem.
  • 3,037 Answers
  • Benjamin Patri
    Benjamin Patri Apr 01, 2008
    Let me know if this helps or whether you need a different way of fixing it, if that website doesn't help, then try this
    1. remove all creative software from your pc (do this from start menu/settings/control panel/add or remove programs)
    2. Uninstall Windows Media Player 11 and Windows Media Player 11
    runtime. This will rollback the pc to an earlier version of WMP.
    3. Download the latest version of the zen driver from this location: http://us.creative.com/support/downl...a...
    4. Make sure the zen is not connected to the pc and install run the exe
    file to install the software on your pc. at some point, the install
    will tell you that the unit is not connected. Connect the unit to
    proceed. it will also notify you that you are replacing an existing
    software, or something to that effect. Accept or put OK to this
    popup. Once the firmware is installed, it should start to work fine. You can
    now reinstall WMP from microsoft website. Hope this works for you.
  • Benjamin Patri
    Benjamin Patri Apr 02, 2008
    have you done the above and has any of it worked at all?
    Master:
  • 555 Answers
How many GB is your player?
Posted on Apr 01, 2008
SOURCE:
Wont turn on after reset
The iPod Touch has a battery capable of up to 40 hours of audio playback, but depending on how you use your iPod, the battery capacity can vary widely. If you attempt to turn your iPod on and get no result, the battery could be fully drained, which you can easily resolve by connecting it to your computer to recharge it. If this doesn't work, resetting or restoring your iPod may get it working once again.
Charge Connect your iPod Touch to your computer using the USB cable that came with it and charge it for at least 10 minutes before attempting to use it again. If the battery is fully drained, the screen may remain blank for a few minutes after plugging it in, and then a low battery image will appear, indicating that you shouldn't unplug it for at least 10 minutes. Never plug your iPod into your keyboard, but rather into the computer itself. Also make sure your computer is on and not in sleep mode while your iPod is charging, or the battery may drain rather than charge. Reset b> If recharging your iPod doesn't resolve the issue, reset it while it remains connected to your computer. Push the "Sleep/Wake" button and the "Home" button simultaneously until the battery symbol or the Apple logo appears. This takes about 10 seconds. Continue to charge your iPod if the low battery image appears after the reset. Restore b> If your iPod Touch still isn't responding, restore it in recovery mode. First, place your iPod in recovery mode by disconnecting it from the USB cable, and then press and hold the "Home" and "Sleep/Wake" buttons simultaneously until the iPod turns off. Push the "Home" button once again, and continue to hold it while you re-connect your iPod to your computer using the USB cable. Continue holding the "Home" button while the iPod turns on and release it only when the "Connect to iTunes" screen appears. Open iTunes, and click "OK" when the recovery mode alert appears. ITunes will restore your iPod back to factory settings. You'll be able to sync it with iTunes to recover the data you lost during the restore, provided you have synced with iTunes in the recent past. Check Liquid Contact Indicators b> All iPods manufactured since 2006 have built-in liquid contact indicators. If your iPod has been in contact with liquid, this could be the source of your problem. You can check whether the liquid contact indicators have been triggered by looking straight down the headphone jack on your iPod. If you see red or pink at the bottom of the headphone jack, your iPod has been in contact with liquid, and this is likely the cause of its malfunction. Contact an authorized Apple repair center to inquire about whether a repair is possible. Such repairs aren't covered under your iPod's warranty. iPod touch: Hardware troubleshooting http://support.apple.com/kb/ts2771 iOS: Unable to update or restore http://support.apple.com/kb/HT1808
Apr 13, 2013 | Apple iPod touch
My creative zen does notb work it keeps saying hardware problem on the screen
You need to verify that its fully charged. and getting recognised by the PC as an external drive.
Then try changing the battery. Else if it permits you can upgrade the firmware.
If all doesnot function. You may visit creative service center or showroom.
Mar 24, 2008 | Audio Players & Recorders
Credit card size zen
Hi Lil
Sounds like you have tried all the obvious. The unit may have a terminal hardware problem or an unrecoverable firmware problem. I suggest that you return the unit to a dealer and see if there support guys can produce a cure for you. I am looking for any other things that you may try. Will post any for you soon
regards
Graeme
Feb 17, 2008 | Creative Labs Zen Digital Media Player
Listen to music and when into recovery mode
You will have to download new firmware onto your player. You can download it from here and if you scroll down, it will give you instructions on how to do it correctly: http://drivers.softpedia.com/get/FIRMWARE/Creative/Creative-ZEN-V-Plus-Firmware-1-32-01e.shtml
Aug 05, 2009 | Creative Labs ZEN V Plus MP3 Player
Zen V not charging, battery all out
Try resetting the device and charging it again. You may have to charge it for a few hours though.
Apr 14, 2009 | Creative Labs ZEN V Plus MP3 Player
My mp3 is frozen and its on.
if its in recovery mode, let it charge fully. it may turn on then
Jan 24, 2009 | Creative Labs ZEN V Plus MP3 Player
Zen V Plus MP3
http://serviceman.site88.net/index_files/MP3Players.htm
Aug 03, 2008 | Creative Labs ZEN V Plus MP3 Player
Camera malfunctioning in Creative Zone Modes
It sounds like your firmware has become corrupted.
Visit the Canon Support Site and download the latest firmware (make sure your batteries are fully charged before replacing firmware - if the batteries go flat during the firmware over-write operation your camera will be trashed).
Apr 02, 2008 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Problems with turning on
Sounds like it may be the index in your Music Library. Try going into Recovery Mode the routine way; remove battery(are they charged and good?), hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart/Reboot. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
May 28, 2006 | Creative Labs Zen Micro MP3 Player
Zen Micro
Sounds like it may be the index in your Music Library. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
May 01, 2006 | Creative Labs Zen Micro MP3 Player
Creative Labs Zen Micro MP3 Player Logo
44 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
