Question about Kitchen Ranges
I can not change oven flame. tightened orifice
Trying to convert stove from natural gas to propane. there are two ovens. i can not change oven flame. tightened orifice down tight,and converted appl. regulator,still too much fire. i have done many stoves but need help with this one.
  • 10,865 Answers
Hello. You are going to need the conversion kit designed for your appliance. You can get it at your local appliance store. This will allow you to adjust the flame. Joe
Posted on May 07, 2010
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
I have a Frigidaire Stove, Model # FGF316ASA. It was changed from propane to natural gas. The oven works well. The burners, however, will only burn a low flame. Is there a solution for this?
When converting an appliance from propane gas to natural sometimes a technician will drill the orifice to a larger size rather than replace the orifices. Either way is fine, but sometimes the orifices don't get drilled to the correct size. The regulator must be on the propane setting if it is a convertible regulator. If your oven is working fine.... the top burner orifices probably need to be checked that they are the correct size. A simple fix.
Tom
Aug 11, 2010 | Frigidaire FGF316 Gas Kitchen Range
Stove converted from natural gas to propane burners work fine but oven has about 8'' of yellow flame and comes up over diverter into oven. air shutter makes no difference full open or full close and...
The orifice, holes that the gas comes out to the burner)s) for the oven was not changed out.Gas is measured in inches, Natural gas runs abourt 5-7 inches of presure, Ppropane runs about 12-15 inches of pressure, much more. The orifices, holes that the gas comes out, for natural gas, are larger to send more gas to burner. With propane, the orifices are WAY smaller, because the pressure is much higher.
Mar 30, 2010 | Kitchen Ranges
Change over to LP on whirlpool oven
All ovens come from the factory set up for natural gas. To convert to liquip propane you must change the orifices. Once you have the proper orifices, you will be able to make the adjustment you desire. You can contact your lp supplier and have them send their techie out as they do this as a free service.
Apr 07, 2009 | Kitchen Ranges
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Apr 08, 2007 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
131 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
