Question about Yamaha AX-596 Amplifier
Hello i was wanting to know if i could hook up my AX-596 amplifier to my Yamaha HTR-5860 reciver
    Brigadier General:
  • 8,546 Answers
I assume you want to slave it to the receiver and drive some more speakers with it.
Connect some RCA cables from whichever channel pre-outs you want on the HTR-5860 to any input on the AX-596.
Set the AX volume to something sufficiently high, run through the HTR's speaker level setup and match the AX volume to match the channels on the receiver. Then leave the AX's volume alone.
If you just want the AX to have access to program sources of the HTR, run the RCA cables to it from one of the VCR1 or 2 Out (but DO NOT select whichever one you use via the front panel). These are not affected by the HTR's volume controls.
Posted on May 07, 2010
Yamaha AX-596 bass & treble control panell not working
Make sure there is no tone bypass button if it has one.
Apr 26, 2014 | Yamaha AX-596 Amplifier
When turning the source selector on my AX-596, is sometimes takes a couple turns for it to change source. Is this an easy fix? dirty switch?
remove the front panel and if you have clear alcohol and just few times over the SW and turn it around that's all
just tell me if it work
Aug 03, 2011 | Yamaha AX-596 Amplifier
The volume shaft is loose.how do I fix it?
Hello, if you gently pull the knob towards you it will come off and youll see a hex nut thats simply loose ,more than likely.
Feb 28, 2011 | Yamaha AX-596 Amplifier
I want to connect YST-Sw1500 sub woofer to the AX-596 amplifier .How can I do the connections .
on ur subwoofer u will see HPF output, connect this output to MAIN IN of ur power amp (first remove jumper between pre-out and main in from ur power amp) connect pre-out of ur power amp to input 2 L&R (Left is also for mono input). the HFP selector switch will cut off 80Hz or 100Hz to the main input depending on the position enabling u to have high frequency sound on your main speakers. connect the speakers to the main output terminal of ur power amp. do not connect speakers on the woofer ouput.
make sure u are using the right impedance speakers. do not switch speaker impedance selector while the unit is on.
Apr 04, 2010 | Yamaha AX-596 Amplifier
I need the code for a yamaha HTR-5860
Go to the company web site for the remote, there should be code there.
Apr 10, 2009 | Yamaha HTR-5860 Receiver
Yamaha amp ax-597
Happy to help, just need to hear from you mate. Cheers
robotek
Aug 29, 2008 | Yamaha AX-596 Amplifier
Matching book shelf speakers for yamaha ax 596 amplifier
just click to choose;
NEW iBALL BOOSTER 5.1 SPEAKERS WITH MANUFACTURER WARRANTY
The iBall Booster is a high quality 5.1 speaker system with complete wood encased speakers. Gives... control...
FREE 350 WATT AMPLIFIED SPEAKERS Creative Inspire 5200 5.1 Multimedia Subwoofer Speaker System With 1 Year Warranty
hope this may help;
Regards,
VOTIT
Jul 27, 2008 | Yamaha AX-596 Amplifier
Hooking up an EQ on a Yamaha HTR 5860
Are you nuts? You dont need EQ to this system.This is such a nice syetem,inbuilt EQ gives very good output.Don't try to connect EQ if you are not an engineer.It can be connected with external source
Feb 10, 2007 | Yamaha HTR-5860 Receiver
Yamaha AX-596 Amplifier Logo
172 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
