Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
What does CFH mean on your pool heater and how do you fix it?
We just opened our pool and went to turn the heater on two days later. CFH appeared on the reading and then the heater started making a loud knocking noise. What do we need to do?
  • 990 Answers
CFH is call for heat and the flame is about to come up. The banging you hear is the water inside the heater overheating to a boil. What you have is a water flow problem. If you have a valve bridging the water into the heater and the water going out be sure this valve is 80-90% closed so it forces water through the heater. If not you may have a problem inside the water manifold on the side of the heater. Their is a water by pass disc inside the header if stuck open will cause the same problem. Also check your baskets and filter to be sure they are clean.
Posted on May 07, 2010
Why do I get CFH but then no SPK?
CFH = Call For Heat
SPK = Ignitor is Sparking - attempting to ignite raw fuel
In a lot of cases, Pressure Switch opens up, CFH , is cancelled and therefor no ignition sequence.
try cleaning filter really good. If cartridge, may be time for an overnight soak.
May 21, 2015 | Raypak RP2100 DIGITAL POOL HEATER R265
What does CFH mean
this is not an error code. it means a call for heat. the pool water temp is colder than your tstat set point
May 25, 2014 | Rheem 266K to 399K BTU Swimming Pool...
Fault/error code GI/O
the error code you are getting is GVO. means gas valve open or stuck open. replace the gas valve
Aug 29, 2012 | Raypak RP2100 DIGITAL POOL HEATER R265
What does CFH means on my control board?
"call for heat", in other words the heater realizes the water temperature is below the set-point on the heater and therefore wants to turn on and heat the water.
Apr 22, 2011 | Raypak 130,000 BTU Propane Gas Pool...
What is CFH
CFH stands for "Call For Heat"
CFH means "Call for heat" and SPK means "Spark". They are status codes, not fault codes.
It basically means that the heater is turning on the heat mode and spark should appear shortly after the CFH code appears. At this point the heater should be igniting and the heater heating up.
If you are having a fault issue with the heater, please let us know if there is anything else that we can do for you!
Dec 16, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
2,833 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
