Question about Bernina Activa 130
Bobbin bernina
When using the bsr on the bernina the I cannott get the bobbin set right it does not look good on the back
  • Anonymous Jul 03, 2008
    BSR stitches several stitches and then skips for several stitches. It then stitches a few more the stitches, finally thread breaks. Have cleaned out lent, changed needle, rewound bobbin, changed thread, loosen pressure. What could be the problem? This is BSR update on a 200. If this is not right place please redirect me.
  • Anonymous Mar 21, 2014
    The winder won't work
  • Bernina Master
  • 1,388 Answers
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
bobbin   bernina - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 30, 2008
  • 202 Answers
Have the spring changed on your BSR. There is a problem with weak springs on the BSR's that has a new solution by Bernina. We are changing the springs to stronger ones now. Whenever one with a problem comes in I do it automatically. Its not easy but I have it down now. You need to take it in to your dealer. Its a new update recommended by Bernina.
Posted on Jul 24, 2008
6ya staff
SOURCE:
How do I get my BSR to work on my 440QE? I plugged it in, but I don't see a light on the foot. Can't make BSR 2 work? BSR2 is on my screen, but won't run.
Try BSR 1. I have a 440 and only one of the BSR settings works--don't know why--just is.
Manual:
BERNINA aurora 440 QE Support BERNINA
Check to make sure the BSR is firmly plugged into the machine head. Don't know why they made this so difficult. I find I usually have to practically stand on my head to find it and then plug it in.
If it still does not work, perhaps Bernina did not calibrate the BSR to your machine. They recommend, whenever it goes for service, to be sure to bring the buttonhole foot and BSR so they can be calibrated.
Apr 04, 2017 | Sewing Machines
Can I add a BSR to a Bernina 1260?
Not really. The Bernina BSR units need to be attached electronically to the machine to activate the "electronic eye." Your 1260 is an earlier mechanical-electronic machine that does not have that electronic-attachment capability, ie there is no where to plug a BSR unit into your machine. However, with practice (both with pencil on paper and then transferring that muscle memory to the machine), you should be able to learn to free motion quilt on your 1260. It just takes practice and patience.
BERNINA Stitch Regulator BSR
https://www.qnntv.com/courses/improve-freehand-quilting-designs-using-muscle-memory
Apr 01, 2017 | Bernina Sewing Machines
Will a BSR work on my Bernina 1000?
Usually a BSR has to plug into the machine somewhere to govern the stitching speed. If your 1000 does not have the capability to plug in the BSR, you would probably be wasting your money.
Aug 17, 2016 | Bernina Sewing Machines
Bernina artista 640 or B 720 witch on is the better choise
Most likely depends on what you want to do with your new sewing machine:
BERNINA artista 640 sew embroider and quilt to perfection BERNINA
BERNINA 720 sewing and embroidery with maximum precision BERNINA
It might be wise to visit a Bernina dealer shop and "pick their brains" to decide which would be the best for you. Searching the internet for reviews on the machines you are contemplating is also a good way to find out how the machine fairs in the real world.
NOTE--if you wish to perform free motion quilting with the BSR unit, be sure the BSR accessory is included with your machine. Purchasing that accessory separately can set you back several hundred dollars.
Jan 04, 2016 | Bernina Sewing Machines
Bernina 770
BERNINA FAQ - frequently asked questions and their ...
https://www.bernina.com/en-US/Support-US/FAQ
How do I send an embroidery design from the computer to the BERNINA 830? ... Which settings give the best result when sewing with BSR (BERNINA Stitch Regulator)? ... Why don't all presser feet appear in the presser-feet display? ... Itdoesn't have sideways-motion patterns and a drag & drop option and it comes with a .
Jun 21, 2015 | Bernina Sewing Machines
I am trying to free-motion quilt using my Bernina 1530. Everything is fine until I quilt a curve or a circle. Then the thread on the back is too loose. I have tried adjusting the top tension, as well as...
I don't have the BSR (Bernina Stitch Regulator) and presume you don't either. I have found that I tend to move the fabric to quickly when sewing curves and circles. I did as you did and changed tension, stitch length...everything, but nothing worked. I finally found that the best solution was to SLOW DOWN on the curves. No problem ever since. I hope this helps you. If it does, please let Fixya know by rating my solution!
Nov 20, 2010 | Bernina Sewing Machines
BSR skips stitches
Hi, I am a Bernina tech and can tell you what the problem is. The problem is that the spring on your BSR is weak. Bernina has an upgrade to adding a heavier spring that solves this problem. The older lighter springs on the BSR is shiny. The newer heavier updated spring is dark. Ask your dealer/tech to change this spring to a new one or give you a newer updated BSR. Also be sure they updated the BSR to the latest firmware.
Rick
Oct 03, 2009 | Bernina Sewing Machines
Bernina Aurora 440 knotting below my fabric and into bobbin area.
Are you sure you have the bobbin the right way round in the holder....when you look at the bobbin and tug the thread, the bobbin should move clockwise.
Pull out the foot pedal and use bsr2 with the start/stop button.
Bring bobbin thread to top of work before starting to sew. This may help knotting problem
May 25, 2009 | Bernina Activa 140
Unbalanced lower tension when using BSR free motion quilting
try using a straight stitch plate, this will help resolve some of the eye lash effect.
Apr 05, 2009 | Bernina Artista 180
Sewing Machines Logo
476 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Wayne Buss
Harjeet Singh
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
