Question about Samsung Dryers
Always set on cooling takes 2 hours to dry small load
  • stefanross96 May 07, 2010
    small apt dryer has heat but not going into the drum. BRAND NEW, cooling light is on all the time, takes two hours to dry a small load, but you can burn your hand on the back of the dryer. nothing in the exhaust vent???
    model# dv665j it works fine but no heat to the drum lots of heat on the back of the dryer, you can burn your hand, the coling light on the front is always on?
  • Samsung Master
  • 19,396 Answers
Hi.
Check if the vent is working.
If the vent is not working, then the vent must be tested by energizing it directly (jumping contacts), then eventually replaced.
If the vent is working, then the only possible explanation for this symptoms is that some part of the air duct broken, moved or out of place. In that case the appliance must be disassembled and checked.
Regards.
Posted on May 07, 2010
  • 15,935 Answers
Please expand your question.
You CAN'T set it to normal?
Or it spins but does not get hot on the normal setting?
What is the model #?
Thanks!
  • 10,865 Answers
Hello. Your timer is bad and needs to be replaced. Also, please pull the dryer out from the wall, disconnect the exhaust pipe and inspect inside the back of the machine and inside the exhaust pipe. Remove any lint. IF it is a long reach you could use a vacuum cleaner hose to clean it. Finally go out doors and make sure the vent is clear and that it is working so no critters can crawl in it. Joe
It's a whirlpool awz 7466. It runs fine, but I do not know which settings it needs to be on to dry my clothes normally. A small load will take at least 2 hours and makes laundry take forever. Any help
Hi Jennifer,
Two hours to dry a small load of laundry (even a large load for that matter) is way too long. You're wasting electricity too. The first thing you should do is consult the manual for the dryer to be sure you've selected the proper setting. The literature for this can be found here.
Consult this literature page 63 for the location and cleaning instructions for the (e) lint filter after each drying cycle and (h) heat exchanger at least monthly. Failure to clean both will result in long drying times. If you have the "Gentle" cycle selected, drying time will be prolonged, too.
Hopefully, these suggestions will help you solve the problem. Good luck!
Jan 07, 2013 | Dryers
Tip
Tips For Dishwasher for its safety and getting dishes cleanest
Find out what the top 7 dishwasher tips are for safety and getting dishes there cleanest are:
  • If your household is small, try gradullay accumulating a full load of dishes and rinsing as you go, instead of stacking dirty dishes in the dishwasher.
  • Cleaners and some elbow grease will always get pots and pans cleaner then the pots and pans cycle on the dishwasher.
  • Good crystal and china should be hand washed and not placed in the dishwasher since the detergents and jostling can damage them quite easily.
  • It can take several hours for dishes to dry when using the no-heat dry option the dishwasher. Try propping the door open to speed the drying process.
  • Place flatware such as forks and knifes with the point side down in the utensil basket.
  • Make sure the heating element at the bottom of the dishwasher is cool before reaching in to get anything from the tub area.
  • The dishwashers door vents emit steam which can harm small children as these are often at a toddlers eye level. Many units have an option where you can lock the dishwasher preventing a child from opening it and crawling in. It's best to keep small children away from the dishwasher.
on Dec 12, 2009 | Dishwashers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Washer has timing issue, says it will wash for 45 minutes and wash for 1 hour and 15 minutes. The cycle says 50 minutes but it ends up taking 75 minutes.
This is really not uncommon. The more and more sophistocated the machines become, the more small decisions they make on their own. I have seen a one hour load take up to 2.5 hours.
If a load is off balanced, it will change the time. If the spin cycle doesn't spin enough water out, it will increase the time, and may still be too wet. (In that case you need to clean out the lint/drain trap.)
If you really want more control and quicker washes, there will be a setting like "Quick wash " or "Fast wash." Theis setting is quite basic and does exactly what you tell it to do, and you can always add and extra rinse, or higher speed cycles.
Kenmores and GEs are the highest reported rate of longer times. Relax. The more you add, ie, delicate, two rinses, light spin, medium dry, the longer it will take. It's just trying to do its job! :)
Sirwriter
May 29, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
It takes hours to dry small load
dud thermal sensor, the temperature is shuttimg off too low
locate, replace the thermal sensor just 'downwind' of the flame
Mar 26, 2008 | Amana NDG7800AW Gas Dryer
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
