Question about Refrigerators
I have just been placed on insulin. I have the Black & Decker BNA17B fridge and I need to know how temps correspond to the control knob inside the fridge. The insulin instructions say the insulin needs to be refrigerated between 36-46 degress F.
  • Darryl Kemp
    Darryl Kemp May 07, 2010
    Thank you so much for the information. I will follow your suggestion and get a thermometer.
    President:
  • 1,218 Answers
Good day,
Mid-range settings (halfway between coldest and warmest) is, on almost all models near 37 degrees.
Due to the sensitivity of your medicine you should as well buy an accurate thermometer to keep track and fine tune as needed.
As well, machines malfunction and the thermometer is the best way of being sure.
Lots of luck.
Posted on May 07, 2010
Black & Decker Toaster Oven CTO650 ... Numbers around dials has worn off. Where can I get a replacement panel?
Search Results
    Black & Decker CTO650 1500 Watts Toaster Oven - Read ...
    www.epinion.com/.../Black_Decker_CTO650_Toaster_Oven.../3529132...
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints Is it really ... Cons:Numbers wear off around dials after years of wiping. ... It has a see-through glass door, 30 minute timer, variable temp up to 450 degrees F and signal bell.
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints i should'a bought this one Is it ... Cons: Numbers wear off around dials after years of wiping. .... It hasa 4-slice or 9 pizza capacity and touch button controls with LCD display.
Jan 28, 2016 | Toaster Ovens
What could be the problem ?Black and Decker mini fridge model BNA17B- Fans run but it doesn't get cold.
THE TWO "330 MICROFARAD CAPACITATOR @ 200 VOLT" MAY BE BAD. MINE WERE. REPLACED THEM AND ITS WORKING FINE.
Apr 28, 2014 | Refrigerators
Black & decker refrigerator bna17b runs all the time. never shuts off. keeps thing cool, but always running.
If, the refrigerator, was working well at first, start and stop cyclically, when was new, the solution is to clean the internal fans, because having poor air circulation leads to the temperature sensor to a wrong reading
If not turned off since new, that's one was made in China and the control board has a bad factory solder, so the refrigerator starts to cause problems when the fans, that are working 24 hours at day, falling on wear or dirty then stop working , causing a lack of cooling and cracking the Peltier modules.
Aug 29, 2011 | Refrigerators
I have a B & D BNA17B mini fridge that won't get cold. Can this be 'recharged' like an air-conditioner?
My BNA17B mini fridge also died but it was not the heat sink. I had a blown fuse and two bad power supply filter caps. The fuse is a 3 amp, soldered to the board. I replaced it with a fuse holder and 2.5A fuse. The capacitors are 330uf 250VDC electrolytics. If you replace yours make sure you get the polarity correct. See photo, you can see the bad cap already removed and the replacement on the board.
Nov 07, 2010 | Refrigerators
My Black & Decker bna17b mini fridge simply does not cool enough. The manual claims it should get down to 37 degrees Fahrenheit in a 70 degree room. I put the setting on high (coldest) and my milk...
Sorry Brian & Charles, but you missed the boat on this one.
This Black & Decker refrigerator uses Peltier Thermo-electric modules on heat sinks. If you blow off the dust and the unit still does not cool, these modules have probably gone bad.
The heat sinks/modules attach to the back of the fridge with two screws each. Unplug the power, remove the screws and then remove the heat sink/cooling fan units. On the refrigerator side will be a smooth plate with two wires coming out of it. Plug the fridge in and touch this plate. If it is not cold to the touch, your Peltier module is bad. You can buy new ones for about $20 each - Parts Express has the Velleman brand Peltier 2 model. But seriously, you'd probably be better off just buying a new fridge.
Nov 06, 2010 | Refrigerators
Fridge and freezer same temp.
First of all, there is only one thing that cools in a fridge and that is the freezer. The fresh food section is cooled by air forced into it from the freezer.
  • You ice maker will not work if the temp inside the freezer is above 5 degrees. It has a thermostat inside it that enables it.
  • The knob that turns the fridge off and on is the thermostat for the freezer.
  • The other knob opens and closes a damper between the freezer and fresh food section.
  • There is a fan that should be running that pulls air from the freezer into the fresh food section.
(The factory does make the discription of the knobs confussing)
Now. turn one of the knobs all the way one way and then the next. If it turns the compressor off, it's the thermostat. If it does not, try the other knob. Once you find the thermostat, set it in the middle of the scale. Now place the other knob the same. Check and see if you can either feel or hear the inside fan running. If so lets go to the back. This is where your compressor is. It is under the fridge and also has a fan that blows on it. You will need to remove the back bottom panel. See if you can tell if the fan is running. Also notice if the fan is blowing into a set if coils. You should also be able to fill the compressor, if it's hot, it's running. If these two are running, and you didn't see a coil at the fan. Take the front kick panel off the fridge and clean the coil that's under the fridge. If it's dirty, give the fridge a couple hours and see if it cools down. If so, this was your problem. If both knobs are set mid scale, both fans are running, the compressor is also running and the coils are clean. You most likely have a bad timer, compressor or thermostat. This is all that's left.
Please rate solution
Sep 16, 2009 | Amana ASD2326HE Side by Side Refrigerator
My problem is that I went to my local Canadian Tier to get help with ordering a part from you people and they have yet to here from some one at your customer service department it has been two weeks sence...
hello there sorry to hear about the problem you are having :
please try this link ok Black & Decker 13760901 TOAST SHADE SELECTOR KNOB
TOAST SHADE SELECTOR KNOB TRO700T/701T/700S AND 700B. Works with the following models: Black & Decker TRO700B, Black & Decker TRO700S. Black & Decker TRO700T, Black & Decker TRO700W, Black & Decker TRO701T.
[93 in stock] Price: $5.95 More details single_arrow.gif
Sep 14, 2009 | Black & Decker Kitchen Appliances - Others
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Changing spool on weed trimmer
unscrew the knob on the bottom(turn cc wise) pull bobbin straight out . To restring pull start rope gently to see what direction it turns and wrap string in the opposite direction. Re insert the string into the corresponding hole(s) and screw up knob by hand until tight.
Jun 22, 2007 | Black & Decker String Trimmer Cordless 12"...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
