Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
Lacie icon not showing up on my desktop
Last night as I was backing up files on my Mac a window came up saying I had removed hard drive without safely ejecting even though I hadn't and now when I plug it in it is not being recognized on my computer and the lacie icon does not show up on my desktop. What can I do?
  • 27 Answers
Try disconnecting the usb cable from the drive and take the drive to a quiet place.
Power up the drive and put your ear next to it. Listen for the internal disk to speed up and then click (which means it's ready). At this point you should have a solid blue LED on the enclosure.
If not, either the disk is bad, the enclosure's controller is bad, or the external power brick is bad (put your ear next to the power brick and if you hear a faint clicking sound, the power brick is bad and you can order a new one from LaCie for about $16.00.
You rate will be much appreciated!
Posted on May 07, 2010
2 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: When I connect my Lacie to my Mac Mini the Lacie
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Posted on Aug 29, 2009
Unmount usb
External hard drives are portable storage devices you can use to back up files or transfer content from one computer to another quickly and safely.
While external hard drives vary in design and storage capacity, turning them off properly is ideal because it decreases the chances of damaging or corrupting files.
Whether you are using Windows or Mac OS X, you can safely eject and turn off your external hard drive in minutes.
Safely eject your external hard drive before turning it off if you have connected it to your computer.
To do so, click the "Safely remove hardware" icon on the system tray on the taskbar. T
he hardware window launches.
Click your external hard drive's icon in the hardware window and click the "Stop" button. You should see the "This device can now be safely removed from your computer" dialog message.
Press the "Power" button to turn off your external hard drive.
Some external hard drives turn off automatically when you safely eject them.
Right-click your external hard drive's icon on the desktop if you are using a Mac, and then click "Eject."
Alternatively, drag your external hard drive's icon from the desktop to the "Trash" bin.
You should no longer see your hard drive on the desktop.
Feb 05, 2014 | Transcend Computers & Internet
I backed up my apple mac osx onto a lacie 320 gig
If its a pc running a different operating system then it wont know what the files are.
Jan 21, 2010 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
My lacie does not show files anymore why?
If the external hard drive was unplugged during a file transfer or without using the Windows "Safely Remove Hardware" utility, there might have been data loss.
If you have a second machine, try plugging the drive into it and see if you can read the drive.
Also, try transferring a file onto the drive, unplug the drive, plug it back in and see if the file is still there. If it's not there, it could point to a problem with the cable. Try to use a different USB cable and perform the same test.
If none of those suggestions work, the drive could have gone bad. It's not uncommon for hard drives to become unreadable due to bad sectors, or mechanical failure. You may need to purchase a new drive.
Aug 08, 2009 | LaCie d2 SAFE 500 GB FireWire 400 Hard...
LaCie icon won't show up on my mac desktop
1. A. Yes.
2. A No.
3. A. Replace the LaCie
Apr 24, 2009 | LaCie Computers & Internet
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
Dec 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 1TB External USB Drive tells me to format when I plug it in
I finally found a solution. I used GetDataBack, it was easy to get, I used the usual torrent sites to get it, and it recovers your files from your hard drive if you have problems with it (i.e. can't access it, etc.). I think my problem was caused by pulling out the usb cord without Safely Removing the hardware,
Sep 25, 2008 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Won't show on desktop
Hi Tom,
My brand new Lacie quadra d2 harddrive decides to show up on my desktop and other times does not. When it does show up, most of the time, it works fine, but sometimes I start up my computer and it simply refuses to show up on my desktop - when this happens I don't hear the harddrive spin up (which is quite loud)  HOWEVER if you just ignore it for 5 mins you'll hear it start up and it appears on the desktop and works fine. Good luck, Sarah
Feb 17, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie d2 Quadra drive... not showing up on PC after working on a MAC
You need to make sure the drive is formatted for the PC. The Mac will read and write to a FAT32 partition, but the PC cannot see a Mac formatted drive as you have seen.
The only problem is that there is a 32Gb limit per partition for FAT32 drives.
It's not ideal but it's the best you can do easily.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Silverscreen problems
I reccomend connecting you computer directly to your tv, depending on which mac you have. DVI or vga. I'm sure the manufacterer does as well. The files maybe in a codec your tv does not compute.
Oct 20, 2007 | LaCie Silverscreen 80GB USB 2.0 - Portable...
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
1,146 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
