Question about Kenmore Kitchen Ranges
My stove has f3 code -what does it mean - Kenmore Kitchen Ranges
  • Kenmore Master
  • 2,605 Answers
Hello, welcome to "fixya".
The F3 error code on 99.9% of all ovens means you have a shorted or open temperature sensor. You will also want to check for any pinched or frayed wires going to the sensor form your clock/erc/timer assembly.
To determine the actual sensor you need you'd have to provide a model number since kenmore is only a brand name for sears, the range itself could be made by any number of manufacturer's.
Let me know if I can assist you further, if not please take a moment and rate the answer I provided for you today and thank you for visiting "fixya" for your error inquiry.
good luck
macmarkus :)
Posted on May 07, 2010
Testimonial: "thanks much for your response! It was fast and very informative"
    President:
  • 949 Answers
F3 is sensor failure. The sensor is metal probe that you can see inside the oven on the back wall. It is a little smaller than a pencil in size. The first thing to check is the plugs from that device to the clock. The wire runs behind the back panel up to the clock. If the plugs are connected tight then you have to replace the sensor. If you have an ohmmeter the reading at room temperature should be about 1080 ohms.
Be sure to unplug the power cord before taking any panels off.
Testimonial: "thx for your very fast and helpful response! "
3 Suggested Answers
  • 22 Answers
SOURCE: Hotpoint stove with f3 code.
Replace the oven control module.It controls the bake and broil including clock and timer functions.
Posted on Mar 31, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Posted on Jan 13, 2010
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
F3 code
I don't think in is unsafe to operate. I worked with boilers that used igniters and a temperature sensors. Usually what these codes mean is (simply error codes ) to guide you which part/s does not function or respond correctly or within a certain time in seconds and brings up this code, but if you get it to ignite, use it like that until you can get someone to do some maintenance on it. Just remember, if your heat is not at the correct temperature, your igniter will fire, but will not be able to ignite the flame.
Meybe lookat this video will make you understand better.
Apr 29, 2014 | Ovens
When my kenmore stove oven is on it shows a code F3 .. what does this mean? ...the oven do not heat up ...mack94
F3 CODE replace the oven sensor its bad / the eoc isn't getting a signal from the sensor and has shut down.. after replaceing sensor it sjould work .. thanks **** .
Dec 04, 2009 | Kenmore 564-91179400 / 564-911714001
What does F3 mean on a GE self cleaning ove. When
Your oven tempertaure senser is bad (RTD)
Jun 25, 2009 | Cooktops
I'm getting a F3 Code and beepingfrom my gas stove/oven.
F3 means open ven temperature circuit you will likely need to replace the oven sensor.
Dec 31, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
I have an f3 code coming up on my stove. the manual says to call a repairman..the stove is 9 years old it may not be worth the repair. can you tell me what this f3 means...thanks
This error indicates the Oven temperature sensor has failed,
You will need to replace the Oven temperature sensor (RTD).
This part can usually be replaced from inside the oven.
Jun 22, 2008 | Maytag Kitchen Ranges
Cleaned stove, replaced bottom element, stove reading F3, F7 and F9. Oven will not work. But will work on Clean Cycle.
Initially, it sounds like a problem with the lock mechanism. Without the brand or model number, it's impossible to know what the fault codes mean. You may find them listed on a tech sheet in a plastic pocket behind the console.
F3 is usually a temperature sensor. F7 may be a keypad problem and F9 (on some machines) means there's something wrong with the door lock.
Sometimes during a self clean cycle, a high temp thermostat/ fuse fails, preventing the door from unlocking.
Mar 09, 2008 | Kitchen Ranges
F3 error code
I keep getting an error code of F3 for my Magic Chef stove model CER3520AAL does anyone know what that means and how to fix it?
Help!!!
Dec 12, 2007 | Kitchen Ranges
Kitchen Ranges Logo
1,059 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
