Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Hard starting 4 cycle trimmer, 20 to 70 pulls
    Scholar:
  • 47 Answers
I got me one of these beasts and I can get her to fire for me in just 3 pulls.
(Oh yeah?! I can name that tune in just 2 notes!!)
Seriously....
Use that primer bulb. Use it with prejudice. Do NOT be afraid of it. What does this mean? Yes. Push it 10 times.
Choke full on.
Full throttle, choke fully on, give it a tug. You should see it hit and give a whitish puff of smoke.
Half choke - Position 2 - Full throttle, another tug. Should fire and rev with you still squeezing that throttle at full. Release throttle and LET IT IDLE at half choke for 30 seconds.
Move the choke completely off, continue to let trimmer idle for at least a minute to warm up the oil and block.
Git to whackin' that yard down. :D I just love my 575ES! (Polesaw attachment for the win)
Posted on May 09, 2010
How to start a Stihyl gas trimmer?
here are the steps to starting most stihl trimmers:
#1 turn the choke on (should be a little black knob or an orange switch on the engine itself)
#2 press the primer bulb 3-4 times (should be a little plastic/rubber bubble again on the engine)
#3 put trimmer on ground or bench (I find ground works best)
#4 pull the pull cord fast and hard away from the engine
#5 once it starts turn the choke back off
Jul 20, 2014 | Stihl Owners Instruction Manual Gas Edger...
My troy bilt trimmer tb20sc rope is hard to pull. It all of a sudden stopped working. Took it all apart. Pull on rope off of trimmer,it still works fine. Took off spark plug, piston is moving up and down....
Jard you need to check that the bottom head is clean and there are no obstructions. Then check that the coil is in tight and the nuts are not loose. Finally have you been using the correct fuel mix? Clean the fly wheel with some lubricant spray and sand paper and re assemble.
Aug 31, 2013 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I can't get it started and I"m following directions on side of machine.
Those direction are not accurate all the time, I usually prime mine 4-6 times. put mine on full choke with the trigger pressed and pull 1 time any more will usually flood it, If you have the choke that kicks off after you press the trigger, put the choke back on to half and pull the cord pressing the trigger, Then pull the cord until it starts without pressing the trigger. As before if you press and hold the trigger during the start it will flood these trimmers..This should start the trimmer. You may have to let the trimmer set for about 15 min if it was flooded.
Sep 19, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Brand new sears 2 cycle gas trimmer is very very hard to start . When you finally get it started and it runs for a while, it will restart easier.
Do you mean hard to start as in you have to pull and pull to get it started or do you mean hard to start as in tough to pull? If you have to pull and pull then the carb screws (gas and air) need to be adjusted. Start by turning them all the way in and the a turn and a fourth turn out and adjust from there. If you mean just tough to pull, the some newer weedeaters have lots of compression and since they come from the factory this way it can't be changed. It will always be tough to start.
Jun 18, 2009 | Craftsman 25cc Gas Line Trimmer
RYOBI GAS TRIMMER 25CC HARD TO PULL CORD. FEELS LIKE TOO MUCH COMPRESSION
YOU CAN ORDER ANY RYOBI SPARES FROM YOUR NEAREST MICA AND THEY WILL ORDER IT FROM RYOBI (011-805-5540) AT MIDRAND. LEAD TIME TWO DAYS
Sep 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Craftsman manual for a 4 cycle lawn trimmer
I have a craftsman incredi-pull 4 cycle, I changed 4 cycle oil, too much smoke coming from the machine, what I can do?
Nov 11, 2007 | Video Game Consoles & Games
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
464 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
