Question about Nokia 1208 Cellular Phone
Test mode message test mode
  • 821 Answers
Hello,please kindly rephrase your question.
thanks,take care.
Posted on May 07, 2010
Resoected sir
i have nokia3110 classic
when wont start my cell, but when it on and then screen is flassing be swichoff, so plaese give parfect sovution.
thnk u
Posted on May 20, 2010
  • Fiuciuc Andrei Nicolas
    Fiuciuc Andrei Nicolas Aug 10, 2010
    I would appreciate the correct usage of English and my solution is true; if you use a non-branded SIM card or anything like that the phone(mostly when it is blocked in a network) will enter the TEST MODE! The only thing you can do(since there is no such data cable/support software for this model) is to go to a Nokia service. They will do you that free or at a low price depending on your warranty!
  • 89 Answers
I think I know what he is saying. Nokia phones, during normal usage go trough the TEST MODE once a lifetime and that happens in the factory! After that, this message will display if an old/innadequate sim card has been installed. To get it off just remove the batery and restart. If it still shows that, then go to a Nokia Service!
Posted on May 11, 2010
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
Oct 11, 2011 | Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    Oct 09, 2011 | HP Mini 1000 Netbook
    I have a Nokia 1209 and it's showing the Test Mode message on the screen. I can't even make a call because of the test mode message. Can you help me?
    remove sim
    press star and three and on switch together for about 5 sec
    mobile will switch on and show hard reset
    pls back up ur data (numbers etc)
    Feb 07, 2011 | Cell Phones
    Nokia 2630 Test Mode
    you need to take the phone to a mobile service center and have them correct the issue for you
    Jul 27, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
    My Cannon Pixma MP110 printer is showing message;- The Waste absorber is full. What can I do to fix this?
    Try this
    Reset Waste Ink
    1) Enter SERVICE MODE.
    By pressing Menu, Copy, Scan, Copy, Copy
    2) Select TEST MODE.
    3) Select [8] PRINTER TEST in TEST MODE.
    4) Select 3. [EEPROM CLEAR].
    5) Select 0. [INK COUNT].
    6) Press the [Set] key.
    7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
    Jul 05, 2008 | Canon Office Equipment & Supplies
    Show test mode
    my handset model1600 shows test mode , how do i turn on phone ?
    thanks
    Feb 29, 2008 | Nokia 1600 Cellular Phone
    Error Message
    Clean the paper sensor located at the centre of the mechanism .
    Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
    To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
    Try feeding labels, only one label should advance at a time.
    This is the calibration procedure.
    Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
    Error message
    Hotpoint’s are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘D:end’ (or similar message)."
    Nov 03, 2007 | Hotpoint Aquarius WD640 Front Load...
    Error message "test"
    yhe washing machine has been put into test mode to get out of this mode you must press and hold down the On/Off and Start/Cancel buttons until "d off" is displayed that will get you out of the test mode
    Jun 24, 2007 | Hotpoint Aquarius WD640 Front Load...
    Nokia 1208 Cellular Phone Logo
    614 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
