Question about Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP AF for Nikon Digital SLR
Where to locate serial numbers on my new lens
I can't find my lens serial numbers on my new tamron 18-270 and 17-50 lens
  • 66 Answers
My Tamron 18-270 has number at bottom side toward tripod hole(when lens is mounted on body)
Posted on May 07, 2010
    Problem Solver:
  • 3 Answers
If you are looking for the serial number to send in for a rebate, it's just to the right of the square cutout and it's between the two asterisks. mine is 6 digits. You have to cut that out and send it in with the form and everything else they ask for. I just called Tamron to get the correct answer as the picture they give you is confusing.
Posted on Aug 05, 2015
SOURCE:
My tamron lens 18-270mm pzd is flickering and having difficulty in focusing. Where can I get it fixed.
Go to the tamron site and find the nearest repair centre to you location
Feb 27, 2016 | Tamron Cameras
Where would I find the serial number on a Tamron 90mm Canon macro lens?
all of my Tamron lenses have the serial number on the barrel of the lens right next to the "Made in Japan" label. When the lens is in the camera the MIJ label is on the bottom side. I hope that helps with your lens
Aug 31, 2014 | Tamron Cameras
Tamrom 80 - 210mm f3.8 - 4 Canon FD Mount Zoom lens
Simple idea? Dont go to F32..just stay at F22 and increase the camera speed one stop.
A little test will give you right calibration
Mar 17, 2014 | Tamron Cameras
"I also purchased a Fotodiox Lens Mount Adapter, Tamron Adaptall II Lens to Nikon Camera. The Tamron lens still will not fit
What mount do you have on the Tamron lens? (The built-in mount.) If it has a Nikon mount, you don't need an adapter at all. If it has the Adaptall mount then the adapter should fit onto the back of the lens, then the combo should fit onto your Nikon camera. If the lens has a different mount then nothing you can do will make it fit.
Does the adapter fit onto the lens?
Oct 16, 2013 | Tamron Cameras
I own a Tamron 200-500 Nikon fit lens. It is coming up with f EE fault. Can you help please.
Turn the aperture ring to its smallest setting (largest f/number) and lock it. You can control the aperture from the camera body, the same way you control it on a lens without an aperture ring.
Aug 08, 2011 | Tamron 200-500mm f/5-6.3 Di LD IF Lens
I cant seem to get the lens to fous on anything within 3 feet when in macro.. am i doing something wrong?
Actually you are doing really well cause the Tamron specifications for that lens is 1.5m translated into real numbers that's 4.92 feet. If you want some serious macro let me suggest the Canon 100mm F2.5 Macro lens it's not all that bad for price unless you get the IS version then it's out of the park well sort of. Most of my macro work is done on a tripod anyway so the IS is a waist for me.
Here is a review on that lens.
http://www.fredmiranda.com/reviews/showproduct.php?product=47
Also is you are using the APS size sensor there is a focal factor of 1.6 so the 100mm lens just grew to 180mm and twice as fast as your Tamron. Cheers
Jan 07, 2011 | Tamron Zoom Telephoto AF 70-300mm...
My tamron 28-75 f2.8 canon mount is not working. It focuses but errors when I hit the shutter. help please. thanks
What error number is shown? If Error 99, this article will guide you through identifying the problem and possible fix.
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 14, 2010 | Tamron 28-75 F2.8 XR AF Lens
Tamron 200-500mm lens on Canon 40D ... when I put the lens on the camera I received an error message stating that ''communication between the camera and lens is faulty, clean the contacts.'' All my other...
Try gently cleaning the electronic contacts on the lens's mount with an eraser. This will remove any mild oxidation on the contacts. If this doesn't resolve the problem, then contact Tamron and ask if there are any issues using this particular lens with a Canon 40D.
Apr 17, 2009 | Tamron Cameras
Will not autofocus
Hey shutterbug72,
According to the manufacturer the first thing you should try is cleaning the lens contacts with an eraser. If that doesn't work you could try removing the battery and reinserting it to reset the camera. It seems to me that if there was a compatibility issue going on you should have seen that from the start. As far as what lens you should buy both Tamron and Canon make very good lenses, but with Canon lenses you shouldn't ever have compatibility issues. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 21, 2008 | Tamron 28-200mm f/3.8-5.6 Super II Macro...
Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP AF for Nikon Digital SLR Logo
3,132 people viewed this question
Top Tamron Cameras Experts
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Ric Donato
Are you a Tamron Camera Expert? Answer questions, earn points and help others
