Question about Fellowes PS70-2CD Shredder
It is jammed. I guess i put too much paper in. any suggestions? Thanks, Nancy
  • 159 Answers
They do have reverse. Also UNPLUG and then pull all paper out by hand it may go other wise you have burnt out the motor.
Posted on May 08, 2010
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
Samsung ML-2250 the printer is no longer able to feed paper from paper tray. Just spins and doesn't print.
Hi, the only suggestion I could give you is to look where the paper leaves the tray to make sure there are no pieces from a paper jam. Some people even tried using a vacuum cleaner to try cleaning it out.
Other suggestion is to make sure you have the proper paper size selected.
Start, control panel, printers, your printer, printer preferences.
The mechanism that lifts the paper in the In tray up to the paper wheels may either be jammed or broken.
I guess that will help.
Thanks for using fixya...
Oct 28, 2010 | Samsung ML2250 Laser Printer
Paper jams with cassette use only
Nancy it may not even be visible to the eye but nast enough to cause the problem.
Get a piec of card, usually that stiff card used for posters cut it to A4 unles it is that size and try dfeeding it through the paper source help it a bit with a bit of a push and even a pull onece it shows, do this several; times until it goes through by itself. Then retry the papoer and see if that has removed the offender
Jun 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
PC1060 canon copier
in your case you have to remove the fuser
I will try to guide you, most of the models are the same.
1-turn off machine and unplug
2-open the side door, you already know where the paper is it's most likely rolled up on a hot long roller, this is the fuser unit
3-with a phillips scredriver(star) remove 2-4 screws that hold the unit, it will have a plug most likely on the right hand side unplug
4-unit should slide out (unless there is a cover holding it
5- you can now see and work on the unit turning the gear by hand to remove the paper.
6-reverse the steps
Aug 12, 2008 | Office Equipment & Supplies
I have a hp photosmart all in one printer with a paper jam under the paper tray. How do I remove the tray to remove the paper? Nancy
exactly at the back side of the printer there is a plastic rectangle in shape you have to gently press and remove that plastic rectangle tray outside and then you can easily remove the jammed paper.
Aug 08, 2008 | HP Office Equipment & Supplies
Paper jam
I suggest you to contact your nearest service center in order to fix this issue:
http://hp.via.infonow.net/locator/us_partner/
Regards,
Sagar.
Feb 07, 2008 | HP Photosmart C5180 All-In-One InkJet...
Printer won't take paper
did you look in the back of the printer?
unplug from power?
Dec 17, 2007 | Dell 922 All-In-One InkJet Printer
Paper jam issue
I finally fixed the problem by running two sheets of heavy card stock through at the same time.  With the machine off, I positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on.  When I turned on the printer, it drew the two sheets through and I guess this reset the paper sensor.  I previously found that only one sheet at a time did't work.
Nov 26, 2007 | Canon PIXMA MP460 All-In-One InkJet...
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Fellowes PS70-2CD Shredder Logo
131 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
