Question about Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas
MY LAARS LITE 2 wont light, the pilot is on, the temporature controls and the presure switch have been replaced...the pool guy is suggesting it could be the gas valve? Thoughts
  • 990 Answers
Often if the pressure switch is open it is because of something keeping the pressuer low rather than a problem with the switch itself. If you take a small wire and bridge the pressure switch and other components in the system. If the heater fires when one of these are bridged that is where your problem. Two wires come from your gas valve and go to the pilot and another two are the safty circut. This is where you will find the components I am talking about. A small black rubber tube covers a place in the wire just above the burners and the pressure switch are the two big trouble spots.
If the black tube is shrunk around the wire then you have had a roll out problem with your flame. If it is your Pressure switch then it could be a dirty filter or a dirty basket. Or it could be a water flow problem and you will have to make all your valves are set to have water run through heater. I hope this helps.
Posted on May 07, 2010
Laars Pool Heater, pressure valve or something else,
bad pressure switch or incorrectly set should have no continuity when off it should when running put on 2000 for ohms should have 500 millivolts when off then turn on and it will start counting down at about 200 should light make sure all connections are good and all safety circuit is good
Jun 24, 2015 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Laars pool heater, model R0096400, and I can not get the pilot switch to push down to lite it. asked a pool service guy come to fix, he could not move it too, and told me that i need a new valve....
your pool guy may be right but before spending any hard earned cash,remove phillips head screw in middle of on/off/pilot knob and remove.make sure there is no debris under knob.squirt spray lubricant along stem wait 10 minutes and lube again.replace knob turn to pilot position work it by pushing down several times.it may stick in down position so gently pry up.my success rate is about 70/30 for this technique
Jul 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Heaters starts up (ignites) and shuts down in 2 secs
usually indicates a flame sensing problem. remove sensor and clean with steel wool .
Jun 23, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Our pilot light on our Teledyne Laars ESG250N will light but our heater wont come on. Can anyone help me find any info on our old heater?
check pressure switch should be 24 volts on both terminals if not bad switch or plugged copper tube you can jump just to check
Jun 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas  Logo
350 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
