Question about Sony KDF-50E2000 50" HDTV
My 3 year old Sony kdf50e2000 lcd tv is shutting off then green indicator light blinks continuously. Sometimes it turns back on by itself. If I turn it off with the remote when the indicator light is blinking it turns back on fine. I have noticed dark and light flickering at times the last few weeks of viewing. Is it safe to say it's the lamp I need to replace? I really don't want to by the lamp if this wont fix the problem
    Top Expert:
  • Sony Master
  • 74,496 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jul 13, 2017
  • 20 Answers
SOURCE: akai PT5998hdtv sets goes on clicks and goes off
Do not panic! Do not throw your TV away like I wanted to! Here is what may be the solution for most of the members who have posted their complaints here recently. I am not an expert, but I followed all blogs from various websites and forums, and the conclusion was the same;replace the convergence board for this model. I purchased it from www.partstore.com and since this Akai is the same model as a comparable Samsung Model, buy the Samsung comparable Convergence board for $77. It came to about $85 after shipping. Call them if you need the exact model #. The Convergence board has two black STK ICs and two colors of wires, a gray kind and a blue kind,all which have 'pins' and can easily be unplugged from the circuit board in the TV. It is basically a complete system that takes less than30minutes to install. It is a simple swap procedure, with no soldering.You only need the new board and a screwdriver! Remove the lower backboard of your TV where the cables are plugged in (do not unscrew all the screws for the screen, as it is unnecessary, and might just damage your screen if you are not careful.) It has a u-like shape and comes off easy.Detach the gray wires connecting your old board to the rest of the circuitry, and detach the blue wires connecting the old board to the circuitry. On the old board, there are connectors marked,from left,blue, green and red. Detach those from the old board, and mark the wires so that you may connect the correct the wires to the new board. You then unscrew the only screw connecting the board to the TV,and unhook the board from the TV. Hook the new board to the hooks which held the old board, and screw the lone screw to the board. Plug the gray cables from the new board to the connectors where the gray cables from the old board were,and do so for the blue cables. Connect the multicolored cables to the blue, green and red, just as was done on the old board. Reattach the cover and test the TV. Please do not replace the two STK ICs only. When I removed my old board, I realized that there was a burn mark, where the ICs were, but maybe it was a fuse.You may replace the ICs only to discover that it was another problem.Good luck, and I wish you all thebest in the repairs. I just savedabout$100 for a repairman just to showup.
Posted on Dec 11, 2008
  • 5 Answers
SOURCE: Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Posted on Apr 22, 2009
SOURCE: Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
I fixed my problem by removing the lamp and vacuuming the hell out of the hole where the lamp lives and also getting all of the dust out of the rear ventilation grids with my vacuum. I put the old lamp back in and what do you know the TV has worked perfectly ever since. My lamp was over a year old and did not show any signs of hazing on the lens that you might see on a lamp that has a ton of hours on it. I just thought I would try to put it back in before I spent a couple of hundred bucks on a new lamp.
TA DA problem fixed.
Posted on May 05, 2009
  • 556 Answers
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
  • 195 Answers
SOURCE: My SXRD 60
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
Posted on Oct 10, 2009
My 50" Sony Wega kdf50E2000
the lamp door cover is not secured properly or the lamp is not inserted correctly. Thats what the 3 blinks is indicating.
Aug 23, 2011 | Sony KDF-50E2000 50" HDTV
I have a sony grand Wega KDF-kdf50e2000 and when you turn the TV on it will work fine for 40 seconds and then go off with the green power/standby indicator flashing. After 40 seconds the TV will come back...
you have a ballast issue this is a common failure for LCD rear projection read this link and you will see why I think this
http://www.fixya.com/support/r3556856-how_to_know_if_it_is_the_lamp_or_ballast
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Oct 28, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv turns off (both video and sound) after running for 20 sec and then turns on after 20 sec. This pattern continues over and over. None of the lights are blinking. Lamp is less than 2 yrs old and is...
TV will show Lamp Light warning if lamp got broken or dead.
Symptoms of TV shows lamp is weak and will be replaced. Weak lamp consume more current than allowed ratings and causing activation of protection circuit that shuts off TV and TV turns on again itself, that is why no blinking red light.
Please replace lamp in your Sony KDF-E55A20 TV, lamp replacement procedure is easy and written in user manual, click Sony Support to download user manual copy, if required.
Always buy Sony original lamp for TV safety, Sony original lamp is available in Sony Accessories Store for $200 with following part number..
A1085447A... LAMP BLOCK ASSY XL-2200U
Hope this info will help you.
Thanks.
Dec 31, 2009 | Sony Televison & Video
T.v turns off about 3 times a day
Its problem of bulb that got weak in result and causing TV shut down.
Replace bulb in TV and I would recommend to buy Sony original bulb for TV safety.
Jul 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Mar 15, 2009 | Sony KDF-E502000 50" HDTV
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
SONY TV KEEPS TURNING ITSELF OFF!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
May 23, 2007 | Sony KV-28FX60 28" TV
Sony KDF-50E2000 50" HDTV Logo
341 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
