Question about Whirlpool Duet GHW9150P Front Load Washer
What do i do when the F/H code displays on the washer?
  • 6 more comments
  • doritosderri May 07, 2010
    I checked the hoses and the F/H code came on again
    both valves opened and let water flow through
    both valves let water flow through during the testing
  • doritosderri May 08, 2010
    thanks for help but none of it worked so maybe i'll have to buy those two parts
    for the part number for the CCU which one is the correct part : 8182689 or 8182695
    okay
  • doritosderri May 12, 2010
    when I opened the drain underneath the washer I found a sock but the F/H code still comes on
    where is the pressure switch tubing located and what does it look like
    President:
  • 949 Answers
The first think to check is the water supply, the F/H can come up of the machine does not sense the right water coming in. Make sure your hot and cold valves are on and the hoses to the machine are not kinked.
If this is okay let me know and we can check the diagnostic cycle if you are up for it.
Posted on May 07, 2010
  • 3 more comments
  • Philip May 07, 2010
    Okay, next is to see if we have both cold and hot coming into the machine the valve internal to the washer could be bad to do this we need to run a diagnostic cycle, Here are the instructions. If you do not feel comfortable doing this let me know
    DIAGNOSTIC TEST
    The washer must be empty and the control must be in
    the OFF state before pressing the touchpad sequence to start the test.
    Starting
    the Test Mode:
    Close the door.
    Push CONTROL/ON (if present on
    this model).
    Select the DRAIN/SPIN cycle.
    Select NO SPIN by
    pressing the SPIN SPEED touchpad.
    Push PREWASH OPTION four times
    within five seconds. (If PREWASH OPTION is not present on this model,
    press RINSE HOLD four times within five seconds.)
    C:00 will light up
    on the display.
    Test Program Control:
    In order to advance to
    the next step of the test procedure, push PREWASH OPTION touchpad two
    times. If PREWASH OPTION is not
    present on this model, press RINSE
    HOLD two times.
    When you get to C:01 the cold water valve will
    open
    When you get to C:03 the hot water valve will open
    Push
    cancel after this to end the test.
    If you get to the C:01 and
    C:03 and either one does not let water enter the machine then the valve
    is bad.
    Let me know if you have questions
    Okay, thank you. The next two things to check are the drain and the pressure switch tubing. The pressure switch tubing is the most likely one but hardest to find the problem. It can have a very small hole in it. I will take it off and put it in water, hold one end tight and blow through it to see if bubbles come up. Anyway, here are the details on getting to the drain and tubing to check
    Since the valve is fine. The other things that can give the
    F/H code are:
    - A bad drain pump, clogged drain sump or drain
    hose.
    - Pressure Switch Hose
    Drain:
    First check the drain hose going into the house drain, make sure the
    drain hose is not too far down into the stand pipe in the house, if it
    is you could be getting siphoning. The drain hose should only go into
    the drain about 6 inches. Check the drain hose for kinks.
    If this
    is okay we need to pull the bottom panel off the washer and check the
    drain trap. The bottom panel should have 3 screws on the very bottom,
    once removed the panel will pull down and out. The drain trap is the
    white piece in the center, the handle will unscrew and you can pull the
    trap out. Be careful to have lots of towels ready as water will come out
    with the trap. Clean this trap and look inside for any thing that might
    be obstructing like lint or a small article of clothing.
    Once clean put back and retry.
    Pressure switch:
    -Take the top off of the unit, there are 3 screws that hold it on, they
    are on the back of the machine. The top will slide back then up.
    Once off, looking from the front, there will be a round device
    (pressure switch) on the right side near the back right up top. It will
    have a set of wires going to it and a black hose. Look down to make sure
    that hose is not kinked or pinched. If you want you can pull it off the
    pressure switch and blow through, it should be clear.
    -If this
    is okay, the only other thing the manufacture says to do is check all
    wire connections to this pressure switch and the other end of the
    harness that connects to the board from the pressure switch.
    - If
    this is okay they recommend replacing the pressure switch and main
    control CCU
    The part numbers for those are:
    Pressure Switch
    8181695
    CCU 8182695
  • Philip May 08, 2010
    I am showing 8182695, but I am using GHW9150P as your model number as shown here. If you model number is different the number may be different
  • Philip May 12, 2010
    Make sure that the pressure switch tubing is clear and not broken. Then try again.
    Pressure switch:
Intuitive type. error code 241 appears what does this mean and can i fix it myself
Hi i googled error code on fisher and paykel and found this link-->
http://www.searspartsdirect.com/washer-repair/error-codes/fisher-paykel-aquasmart-top-load-washer-error-codes.html
If you scroll down the page in the link the error code 241 says
"Motor control module failure", Unplug the washer and replace the motor control module. OR
"Display module failure", Unplug the washer and replace the display module...... Good luck...
Mar 11, 2016 | Fisher and Paykel Washing Machines
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Unimac. Why is it displaying E FL and won't spin?
Unimac Washer Product Support ' ManualsOnline.com
laundry.manualsonline.com/support/unimac/washer/
Unimac Washer uw60b20u80001. 0 Solutions ... on start up unlock door light stays on.display sa. Unimac ... washer has falt code E FL what does this mean and.
E fl error code on industrial uni Mac washer. What's it mean ...
www.fixya.com/support/t20744713-e_fl_error_code_industrial_uni_mac
Jan 07, 2016 | Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Kenmore he4t washer codes
The control for the washer likely detected a problem. The failure code will not be displayed on all models of washers. You can recall the error code by using this procedure:
  1. Select the "Drain/Spin" cycle.
  2. Select No Spin.
  3. Press the "Prewash" options and hold this button for 5 seconds.
  • Immediately after those 5 seconds the last stored failure code is displayed for 4 seconds.
  • After those 4 seconds the display switches automatically back to the selection mode
NOTE: If your washer does not have the Pre-Wash option. Then use the 2nd Rinse button (called Extra Rinse). The failure code should stay in the memory so that it can be recalled as often as necessary and as long as it is the youngest failure Code.
Nov 30, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
"F" code is displayed
Kenmore Washers that appear with an error code usually follow with a number after the "F". To help you find some solutions to your Washer getting stuck in an error code. Check this LINK for image zoom...
Visit this Image Link
Hope helps.
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
53 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
