Question about Whirlpool GBD307PD Electric Double Oven
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the display looked fine. Later in the day, the display went blank. We can hear the tones when we press buttons, but nothing appears. The light in the oven still works. The oven did not heat up when we pressed the bake - start - temp sequence. We're not sure of the exact model number, but it looked like this one.l Our owners manual is for GDB277, GDBS277... YGBS307. Do you have any suggestions?
    Dedicated:
    Visited the website for 20 consecutive days.
  • Whirlpool Expert
  • 84 Answers
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Posted on Jun 06, 2017
  • 87 Answers
SOURCE: Oven Won't Work!!
Replace the elecronic module
Posted on Jun 10, 2007
  • 116 Answers
SOURCE: whirlpool gold accubake GJP84802
If you can gain access to the clock you could find the wires that goes to the bake element - if you can measure and confirm the resistance of the element chances you may have also fried the relay of the board - check it out
Regards
Posted on Sep 06, 2008
localwonder
  • 6784 Answers
SOURCE: My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Posted on Aug 08, 2009
Macmarkus
  • 2605 Answers
SOURCE: Oven display went blank. Has Power.
Hello, The first thing I'd look at is your owner's manual to insure the timer hasn't been set to "Sabbath" mode accidently. If that is the case you could experience a "no display" scenario. The manual will also explain how to enter/exit the "Sabbath" mode. In the event the timer itself is at fault ( i.e. the display transformer gone bad ) it will have to be replaced or (if an available option exist's for your timer) have your timer rebuilt. Hope that help's and please take a second and rate the info provided by me here at fixya. Thank you and good luck. macmarkus :)
Posted on Dec 07, 2009
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Posted on Feb 01, 2010
What do I need to do to fix a blank screen on a whirlpool built in oven?
Often the Whirlpool built in ovens have a control board failure which causes the screen to go blank. May be intermittent and may be accompanied by an E6 F2 failure code on the display (before it blanks out). We rebuild a lot of control boards for this problem. For example see:
http://www.fixyourboard.com/boards/8302967.html
Mar 18, 2015 | Whirlpool Ovens
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Error code on my oven, what does it mean?
I have a Whirlpool oven that is 10 years old or so. The oven stopped working today. The code that came up was E3 (in green) and F1 (in red). I would like to know what is wrong with the oven? Please send me a solution. Thanks
Nov 15, 2008 | Whirlpool RBS305PDS Electric Single Oven
Jenn-Air Convection Wall Oven, WW2780
I your user Manuel should be a list of error codes describing what each error code indicates!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 06, 2008 | Ovens
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Mar 28, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool GBD307PD Electric Double Oven Logo
112 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
