Question about Kenmore 22622 Top Load Washer
Kenmore washer won rinse waer out model 22622100 any suggestions?
  • Cole Elliott
    Cole Elliott May 11, 2010
    it it going thru the full cycle and not draining?
    President:
  • 1,937 Answers
See the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22622100&pathTaken=partSearch
I'm assuming that it won't drain. Will it spin????
If it will neither drain NOR spin. I'd check the Lid Switch:
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
If it WILL spin but simply won't drain. I'd pull the cabinet (See above) and check the pump and hoses for any blockage.
Posted on May 07, 2010
How do I get my kenmore 111, Model 22622100 to drain and spin
your pump or the filter is blocked up
something wrong with the drain to waiste ... side
Dec 06, 2014 | Kenmore Washing Machines
My washer won't spin when its on rinse cycle
What is the complete model number of your unit?
Dec 05, 2012 | Kenmore 43142 Front Load Washer
Need schematic diagram for 22622100
Please check this general diagram to identify the parts:
click on : washing machine parts
Jun 27, 2012 | Kenmore 22622 Top Load Washer
Kenmore model #22622100 top load washer. My question is our washer has a sour smell and we have pulled it out from the wall. We are wondering how to take the top off.
First, see the Sears parts site for your washer with diagrams and parts lists. Always a good reference tool.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11022622100/0582/0153200?pathTaken=&prst=0&shdMod=11022622100
Next, see the following for how to release the console and remove the cabinet:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0da65cea0e338fe930b1fde153a243f0
As a final reference, see the following Whirlpool / Kenmore Service manual for top load, direct drive washers:
Feb 12, 2011 | Kenmore Washing Machines
Kenmore model 22622100 how do i get it apart, like take the top off
First, see the Sears Parts site for your washer.
It has a complete set of schematics and parts / prices for your washer.
Second, see the following illustrated description of how to remove the cabinet and get access to the console.
Dec 12, 2009 | Kenmore 22622 Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Feb 13, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine doesn't rinse
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. Check as well that pump spins and clean from any clogged. Good luck!
Oct 08, 2006 | Kenmore 43042 Front Load Washer
Kenmore 22622 Top Load Washer Logo
265 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
