Question about Schwinn Meridian Adult 26-Inch 3-Wheel Bike
How do I adjust the rear band brakes? - Schwinn Meridian Adult 26-Inch 3-Wheel Bike
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: how can we adjust the
http://www.schwinnbikes.com/media/uploads/blog/files/Schwinn-Meridian-Manual_Mar2011.pdf
Page 25
Posted on Jul 13, 2011
Change breaks sears tractor model 917.25640
http://c.searspartsdirect.com/lis_png/PLDM/00027588-00003.png
On the sears site the brake band is part number Brake band PART NUMBER: 634A167
Substitution: 101230K . The band is number 17 on the parts diagram. You'll find it on the rear left side. If the band is in good shape ,it can be adjusted by turning the turnbuckle on the brake rod.
Jun 07, 2014 | Sears Garden
How to install brake bands on a tsm 3000 draworks
If you want to solve your problem, click on the link I attached
Best Manuals
Jul 28, 2017 | Heavy Machinery
87 cutlass no reverse
foward and no reverse.In order for the reverse to happen there is a transmission brake assemble,the transmission band holds the brake assembly thus allowing fluid to be driven according to gear selection, when no reverse happens there is a malfunction of mechanical or hydraulic part, Depending on the condition you can adjust the kick down or adjust the band. A general procedure for automatic transmission band adjustment involves tightening the band adjusting screw to a given torque sequence, back off the adjusting screw from turning while torque-tightening the adjustment screw about a 1/4 turn and lock down the lock nut,and recheck to see if reverse has been restored.
Apr 23, 2011 | 1987 Oldsmobile Cutlass Supreme
How do you change rear drum brake shoes on a 1999 couger.
SECTION 206-02: Drum Brake 1999 Cougar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 09/14/2001 Brake Shoes Removal
  1. Loosen the wheel nuts.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02.
  1. Remove the wheel.
  1. Release the brake shoe automatic adjuster.
  1. Remove the brake drum.
    1. Remove the retainers (if equipped).
    1. Remove the drum.
  1. Make sure that the hub flange is in the correct position as shown.
  1. Remove the hold down springs.
  1. Disconnect the parking brake cable.
    1. Lever the secondary shoe outwards.
    1. Disconnect the cable from the secondary shoe.
  1. Disconnect the shoes from the anchor block.
    1. Remove the lower return spring.
  1. ani_caut.gif CAUTION: Do not damage the wheel cylinder boots.
    Detach the shoes from the wheel cylinder.
  1. Hold the wheel cylinder pistons in place with a rubber band.
  1. Remove the upper return spring.
  1. Remove the primary shoe from the strut and brake shoe adjuster.
    1. Rotate the adjuster counterclockwise.
    1. Remove the primary shoe.
  1. ani_caut.gif CAUTION: Take care as the strut support spring is under tension.
    Detach the secondary shoe from the strut support.
    • Detach the strut from the shoe by levering the strut against the shoe.
  1. Remove the parking brake return spring.
Installation
NOTE: Install new shoes as axle sets.
  1. Clean, check and apply Silicon Dielectric Compound D742-18A331-A or equivalent meeting Ford specification ESA-M1C171-A to the backing plate contact points.
  1. Install the parking brake return spring.
  1. Install the secondary shoe to the strut and brake shoe adjuster.
  1. Install the primary shoe to the strut and brake shoe adjuster.
    1. Install the primary shoe.
    1. Rotate the adjuster fully clockwise.
  1. Install the upper return spring.
  1. Remove the rubber band holding the wheel cylinder pistons in place.
    Position the shoes to the wheel cylinder.
  1. Position the shoes to the anchor block.
    1. Install the lower return spring.
  1. Install the hold down springs.
  1. Install the parking brake cable.
    1. Install the cable to the secondary shoe.
  1. Install the brake drum.
    1. Install the drum.
    1. Install the retainers (if equipped).
  1. Install the wheel.
  1. Operate the brake pedal to achieve automatic adjustment.
2010&c18=modelyear&c20=g167866&c35=wsm%2cbrake%20shoes%2csxu%2c206-02%2cremoval%20and%20installation&s=1249x702&c=32&j=1.3&v=y&k=y&bw=910&bh=359&ct=lan&hp=n&[aqe]
Mar 05, 2011 | 1999 Mercury Cougar
I'm looking for a way to adjust the E-Brake on my Homelite 18" Chain Saw. Its model UT10830. The Saw runs great it just seems that the Brake keeps it from cutting properly by not allowing the chain to turn...
remove the nuts that hold the bar & the screws that hold the cover on.w/ brake off,remove cover.inside cover you will find 'band' brake that surrounds sprocket assembly.if adjustment is provided,it will be at one end of the band.it's more likely to be an accumulation of sawdust interfering w/brake.also clean sawdust from chain oiler holes in bar,and around sprocket while you've got it apart.slacken chain adjuster screw to aid re-assembly,re-adjust chain
Sep 26, 2009 | Garden
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
Jeep grand cherokee revs for to high before changing gear
Message:
My 2002 Dakota has been somewhat confused about shifting as well. It showed a code P1762. I dropped the pan to install a new fluid filter and fluid-(use only ATF+3 or ATF+4). Since the pan was off I decided to adjust the bands. The front band controls the 2nd gear cluster. The rear band controls the 3rd gear cluster and reverse. For a 2-3 shift, the transmission shifts back to 1st gear with the front band while the rear band engages 3rd gear. If the front band does not release the 2nd gear clutches before the third gear clutches engage, the transmission binds, which shortens the life of the transmission clutches. If the front band releases too early in the shift, the engine will overspeed (sounds and feels like a slip) during the 2-3 shift.
The front band adjusting screw is on the driver's side above the shift linkage. The rear band is inside the fluid pan near the filter.
1. Loosen band adjusting screw locknut. Then back locknut off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw
threads if necessary. The front band adjuster is on the outside of the transmission and the locknut requires a 3/4" wrench.
2. Using Inch Pound Torque Wrench C-3380-A, a 3-in. extension and appropriate Torx� socket (T-40), tighten adjusting screw to 72 in-lb. CAUTION: If Adapter C-3705 (from SPX Miller) is needed to reach the adjusting screw, tighten the screw to only 47-50 in. lbs. torque.
3. Back off adjusting screw the number of turns listed below for your transmission.
4. Hold adjusting screw in place and tighten lock-nut to:
41 N�m (30 ft. lbs.) for the front band
34 N�m (25 ft. lbs.) for the rear band
The adjustment screw inside the case is a square head bolt. You will need a 1/4 square head socket to fit your torque wrench.
Band adjustments for each model year:
1994
* Front Band - tighten to 72 in-lb, back off 2-1/2 turns (all transmissions)
* Rear Band
o 32/42RH - Tighten to 72 in-LB, back off 4 turns
o 36/37/46/47RH - Tighten to 72 in-lb, back off 2 turns
1995-1996
* Front Band
o 42RH - tighten to 72 in-lb, back off 2-1/4 turns
o 46RH - tighten to 72 in-lb, back off 2-7/8 turns
o 47RH - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE/RH - tighten to 72 in-lb, back off 4 turns
o 46RE/RH - tighten to 72 in-lb, back off 2 turns
o 47RE/RH - tighten to 72 in-lb, back off 3 turns
1997-1998
* Front Band
o 42RE - tighten to 72 in-lb, back off 3-5/8 turns
o 46RE - tighten to 72 in-lb, back off 2-7/8 turns
o 47RE - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE - tighten to 72 in-lb, back off 4 turns
o 46RE - tighten to 72 in-lb, back off 2 turns
o 47RE - tighten to 72 in-lb, back off 3 turns
1999
* Front Band
o 42RE - tighten to 72 in-lb, back off 3 turns. (TSB 21-16-98)
o 47RE - tighten band adj. screw to 72 inch pounds, back off 1 7/8 turns
* Rear Band
o 47RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
+ The 47RH rear band requires a 1/4" hex driver, the front band requires a
T-30 Torx driver, the filter is held in place by two screws which require a T-20 Torx drive
2000-2002
* Front Band
o 42RE - Tighten band adj. screw to 72 in-lb, back off 3 turns
o 44RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
o 46RE - Tighten band adj. screw to 72 in-lb, back off 2 7/8 turns
o 47RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
From Bill Konolday's 47RE notes: I usually go a little looser than factory
specs on this front band - backing off the adjustment screw 2 or 2 1/4 turns.
Depending on the circumstances I have backed off the band up to 2 1/2 turns.
* Rear Band
o 42RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 44RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 46RE - tighten band adj. screw to 72 inch pounds, back off 2 turns
2003
* Front Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 1-3/4 turns
* Rear Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
2005
* Front Band
back off front band adjusting screw 1-3/4 turns for diesel vehicles,
or 1-1/2 turns, for V-10 vehicles.
* Rear Band
94+ Automatic Transmission Bolt and Nut Torque Specs
* Front band adjustment locknut - 30 ft-lb
* Rear band adjustment locknut - 25 ft-lb
* Transmission pan bolts - 13 ft-lb
I just replaced the solenoid with the recommended transducer and all is fine now. The transducer cost me about $50 at a nearby dealership.
Hope this helps. -zman. rroszman@yahoo.com
Dec 09, 2008 | 2001 Jeep Grand Cherokee
How do I adjust the Leechi bicycle brake. front & rear each need to be tighter on Holstar Montana 26 girl's bike???
find where the cable makes contact near the wheel, with the lever of the brake. squeeze the 2 levers toghether(rubber-bands are useful) then loosen the bolt holding the cable. take out some of the slack and re-tighten. remove rubber band. repeat as necessary to achieve desired tension. hope this helps!!?
Nov 16, 2008 | Mountain Leechi Right Bicycle Brake Lever...
ABS,Brake light "on" and speedometer not working correctly
Rear Sensor replacement 44.95 retail
Shop Labor 60.00
This will fix the ABS and Brake lights, will fix the speedometer isue and smooth out the erratic shifting.
Aug 05, 2008 | 2000 Dodge Durango
Schwinn Meridian Adult 26-Inch 3-Wheel Bike Logo
1,442 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
