Question about Toro Lawn Mower With Toro Power Tools
My son put my lawn mowe in an incline position oil came out and i try to started it work but it smokes and it turn off what should i do
  • 2,100 Answers
Clean the spark plug, toss a little gas in the cyl, pull the cord, If that doesn't do it, let it set for a while, the oil will settle down, and it will start again. Just keep the plug clean. Hope this helps.
Posted on May 07, 2010
RM40 Manual
Hi there
My son was mowing our Scout Hut grass using our RM40
lawnmower. He had cut the main area of lawn & tried to cut some longer grass near a gate. The mower got jammed & started smoking so he switched it off. Now the motor seems to be working but the blade is not turning. Any idea what the problem might be?
Mar 14, 2012 | Garden
Have an old model riding lawn mower, the mower stated to smoke under the engine. Stop for a while to cool off and started mowing again and cutting belt broke, replaced it. Now the blades want cut, but when...
try removing the belt and try to spin the blades by hand. are they stiff to turn? if yes try to oil the bearing assys up under there and spin em again. if that seems to work out put the belt back on and mow away again! seen this on a neighbors rider a few times
Nov 06, 2017 | John Deere Garden
Some water got into my gas can and I put the gas in the mow unaware of it. I mowed for about 30 to 45 minutes when the mow's engine begin to make a popping sound. IWhile draining the gas tank and...
If there is gas in the oil you drained from crankcase the carb is really dumping fuel(did you see black smoke?) If your carb has a drain plug drain it. If not you will have to take off the carb bowl and clean it. Check float operation, turn on fuel work float by hand to make sure gas shuts off when float rises to level position. If not may need needle and seat kit. Or adjust float.
Sep 28, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My daughter added oil then proceeded to mow the lawn. mower started smoking then quit. When I got home from work I was able to start the engine one time and it smoked a lot. I turned it off and have not...
With the engine cold, check the oil level. Oil level is quite important especially in a smaller engine. Try to clean all excess oil off engine and body. Then, if you can get it running....check for any leaks. If it is still smoking, it has other issues besides being too full of oil. The oil breather will be full of oil. The oil filter may be saturated with oil. Check those 2 things especially as they allow motor oil to be drawn into the carburetor and cause excessive smoking. Pull out and clean the spark plug. Post back if needed.
Aug 28, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
MY Kawasaki FH500V commercial lawn mower engine won't start.
Try cleaning the throttle body. If it runs on carb-cleaner being sprayed into the intake then you have a fuel delivery problem, if not you'd be more inclined to more serious mechanical failure. I assume if you use it every day you do the regular oil changes, air filter cleaning, and air-cooling system cleaning, correct? Please indicate if you had a white smoke, blue smoke, or black smoke from the mower too. The motor spins freely when attempting to start, and just doesn't fire, correct?
-JMFT
Oct 01, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn Mower smoking/mufler leaking oil
I have a yardman lawn mower that is two years old. It is now blowing oil out the exhaust and also blue smoke. Any idea what is wrong?
Jul 22, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
White smoke
White smoke is most likely cause there is to much in the engine.. Only takes about half quart.. Clean with degreaser and garden hose on the outside..
Jul 04, 2009 | Garden
I have a Murray riding lawn mower Model 425600x8A. Recently, my son and I were using it to mow on a hill when it starting putting out a thick white cloud of smoke. We shut the engine off and let it cool...
The oil entered the cyliders when the mower was tipped at a severe angle. It will clear out after you run it for awhile. Check the oil level to make sure it is full. It could even be overfull and this is what caused the smoke. If it starts to run badly, check the spark plug or plugs. They could get "fouled" from the oil. Change the if the are black or covered with oil. It shouldn't have done any damage to the engine.
Jun 23, 2009 | Garden
Oil causing a problem?
Sound as if you have too much oil in the machine. Anytime you see white or lite gray smoke it is a sign of too much oil. Before you go through the routine of cleaning the oil out of every nook and cranny, try unscrewing the spark plug and clean it with a soft rag. It would have oil on it preventing the machine from starting. If this does work and there isn't a lot of oil in the gas tank now, just continue running the engine until the smoke clears. It won't hurt anything. But if cleaning the plug doesn't help you will have to empty all gas and oil from the gas tank, refill with new gas, squirt a little gum out carb cleaner in your carb to remove any oil there (this can be done when you try to restart the engine). Remember, when you are mowing grass if you are mowing on a hill) of any knd, make sure to turn the mower so the gas tank is on a higher level than the oil.
Jun 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
101 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
