Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Not dispensing liguid normally, but does dipense when wand is installed
  • 294 Answers
Based on your desription, I believe the issue is with the resevoir (the valve under the clean water tank) this controls the solution to the floor brushes. The other possible cause could be the diffuser just above the brushes could be clogged with soar or mineral deposits. these can be cleaned with a small needle.
Posted on May 07, 2010
Dyson no suction in upholstery wand
Hi there, it's Jack at Dyson.
Like most Dyson upright vacuums, DC18 is engineered to divert suction to the hose and wand automatically when it's standing in the upright position. If your DC18 doesn't seem to have suction from the wand when standing upright, you may have a blockage in the hose or wand. Please follow the steps shown in our online Support guide to check for this: http://www.dyson.co.uk/support/dc18/dc18-all-floors/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/no/remove-the-wand-from-hose
It's also a good idea to give the filter a wash - in normal use, this should be done at least once every 3 months as shown in the video below. Use cold water without detergent, and allow at least 24 horus for the filter to dry completely before replacing it.
I'm confident following these steps will resolve the issue. However if you'd like any further guidance from our experts after you've given this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 27, 2014 | Dyson DC18 all floors Bagless Upright...
How to install the wand handle catch
If the wand keeps coming away from the machine then it is likely that on the back of the machine the four pegs that hold the wand in place 1 or more are broken.
If this is the case then the fault is not the wand but the spine of the machine. You would require a new or sevond hand spine and it would mean completly stripping it.
Apr 02, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Install wand handle catch
You line up the spring, place the two top prongs behind the lip on the wand and gently snap it home onto the two locating pins. You can also now get a workshop manual for the DC07, it is item number 0955687411 on Amazon.
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction when using wand on electrolux precision upright
There is a ball valve between the wand hose and the base hose. It can get stuck in the "base" mode, which won't then redirect suction to the wand hose. There is a spring under the cup that the open end of the hose rests in. When you release the wand from the holster with the one-touch quick release, that spring pushes the cup up and turns the ball valve to the wand setting.
  1. Unplug the vacuum.
  2. Using the one-touch quick release, remove the wand from the holster.
  3. Verify that the wand "cup" is indeed in the higher position. Do this by pushing on the bottom of the cup with your finger. It should easily depress.
  4. Remove the wand hose from the main unit using the quick disconnect feature. Put your fingers into the hole and feel to the right. You will feel the closed valve, verifying that it is stuck in "base" mode.
  5. Using a screw driver, insert the tip at the TOP of this valve and gently pry it downward. This shouldn't take much force.
  6. Reassemble the hose wand using the quick connect feature and reholster the wand.
  7. Plug in the unit and verify that the base unit has suction.
  8. Remove the wand from the holster and verify IT has suction.
Jul 27, 2013 | Electrolux EL8807A Precision BrushRoll...
Model DC40, the wand doesn't have any suction when I want to use on stairs, etc.
If your DC40 doesn't seem to have suction through the wand but picks up as normal on flooring, it's likely there's a blockage in the wand or hose. To locate and remove any obstructions, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc40/dc40-multi-floor/my-machine-is-not-working/machine-not-sucking-up-well/check-the-wand-and-hosedc40
It's also worth giving both filters a wash as shown in the video below - in normal use this should be done at least once a month. Use cold water without detergent and at least 24 hours for the filters to dry completely before replacing them.
I hope this helps, but if you'd like any further assistance please call our freephone Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 04, 2013 | Dyson DC18 all floors Bagless Upright...
I have little no no suction in my DC14 wand
must be a clog in wand?
Check to see if there's suction during normal vacuuming.
if so, there's a clog for sure in wand.
Sep 27, 2010 | Vacuums
Vacuums normally but no suction through the wand
Keep cleaning ... there is a clog somewhere.
Thanks for your intrest in FixYa.com
Feb 19, 2010 | Fantom Vacums XT450K Upright Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
242 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
