Question about Sony Toshiba Qosmio F45-AV411 Notebook
How to replace wireless card. or find a service manual.
  • 408 Answers
The wireless card is either under the keyboard or under one of the obvious doors on the bottom.When located be careful when removing the antenna wire that snap on to the card its self.
Posted on May 07, 2010
Testimonial: "Thanks! That was the problem = Intermitent Internet due to loose wire. Thanks. You're the man :-)"
  • 53 Answers
Contact the manufacturer, as this is a latest notebook
Posted on May 08, 2010
Netgear N150 Wireless usb adapter just installed. It identifies router and confirms good connectivity, but continues "acquiring network address" without success.
This means the DHCP service is not enabled on the wireless router.
either enable the DHCP service on the wireless router
or
Give a static IP onto your wireless NIC card ( Netgear N150 Wireless usb adapter )
Dec 06, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Lost wireless internet connection. tried to do the repair function numerous times, filled in the wireless information manually, and finally cleared and reinstalled to factory settings. Still will not get...
Before you replace the network card (which is pretty easy on a desktop, a little trickier with a laptop), reset your router. Look for the router reset button and reset it (you need a paperclip).
Oct 16, 2017 | Gateway 7320GZ Notebook
Acer Travelmate 2500: Where's the wireless card fitted?
go to http://tim.idau/laptops download your service manual it will show where wireless card & bluetooth card are installed, good luck .
Jan 04, 2010 | Acer TravelMate 2500 Notebook
How do i replace the wireless card in my lenovo 3000
Access for the wireless card is under the access door for the hard drive. The guide below is for both wireless "B" and "G" cards which have two wires. It also has the reattachment guide for wireless "N" cards that have three wires. The attachment guide is below for proper lead placement. a link below wil take you to the service manual for this laptop, the numbers for illustrations match the repair manual.
1040 PCI Express Mini Card for 802.11 a/b/g wireless LAN
For access, remove these FRUs in order:
v “1010 Battery pack” on page 46
v “1020 Hard disk drive slot cover” on page 47
In step 2, unplug the jacks by using the removal tool antenna RF connector
(P/N: 08K7159) or pick the connectors with your fingers and gently unplug them
in direction of the arrow.
When installing: Plug the white cable into the jack labeled MAIN on the card,
and the black cable into the jack labeled AUX.
When installing: Plug the black cable (MAIN) into the jack labeled 1 on the card,
the white cable (AUX) into the jack labeled 2, and the gray cable
(MIMO) into the jack labeled 3 on the card.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/42x3553_03.pdf
Nov 29, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
I cant manually activate my blackberry pearl I went to options, mobile network but all it says is roaming.
See if this works....
-Press menu key
-Click OPTIONS
-Select Mobile Network
-Click on "START PROVISIONING"
It should give you a message saying: PROVISIONING COMPLETED SUCCESFULLY.
You wont need a MSL code if you do it this way.
Nov 13, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
How do i replace the keyboard
1) Buy a new keyboard
2a) Go to a service center and let them do it
2b) follow instructions from here:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/remove-wireless-card.htm
It's a manual for the wireless card removal, but should work for the keyboard as well.
Nov 10, 2009 | Toshiba Satellite® A215-S4807 PC Notebook
I want to replace the wireless card on my hp notebook
here is the link for service guide from hp
the wireless card info is on page 132
http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
for safety please read entire manual
good luck
Nov 03, 2009 | HP Pavilion dv9000z Notebook
How do I set up a wireles connection for a Dell Dimension 8300
You will need a a couple of things to set up a wireless connection.
First you will need a wireless card which can be either a pci (you have to insert it inside the pc) card or a usb wireless adapter.
Then you will need a wireless router. You will connect your modem to the router which will communicate with your wireless card.
You may need to start windows wireless service ( I say may depending on your wireless card your card may come with software to manage your connection or you may not like the software whatever the case maybe you can always use windows to manage your wireless connection) in XP open control panel click administrator tools and open services then scroll all the way down to Wireless Zero Configuration open it and set startup type to automatic and then start the device click apply and close. This should be the only time you have to manually start this service now that you have set the startup to automatic.
While you are in control panel open Network Connections find your wireless card and right click then click properties you will see two boxes on the bottom select both of them then click ok. That will create an icon on the toolbar for your wireless connection to access it right click for options.
Oct 18, 2009 | Dell Dimension 8300 PC Desktop
I cannot connect to my wireless because I was told that my wireless card went bad. What is the next step to get this corrected
how does an internal wireless card "go bad"? unless you got it wet and it short-circuited... but you should really be able to just download the broadcom driver and then the wireless driver. don't rate me on this, but i don't think it's your card, but rather your router. my router has been sucking teabags lately.
Oct 11, 2009 | Dell Inspiron 6000 Notebook
Sony Toshiba Qosmio F45-AV411 Notebook Logo
76 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
