Question about Whirlpool LHW0050PQ Front Load Washer
Can I clear an f30 error on my whirlpool washer??
  • 15,935 Answers
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Posted on Sep 28, 2010
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
My washer is giving me an error message of F30 and it makes humming noise like it wants to come on but it doesn't.
The fault guide says the following about F30:
DISPENSER SYSTEM ERROR
The dispenser motor cannot be driven to its proper position
1. Unplug and disconnect power
2. Check mechanical linkage from dispensor motor to top of dispenser
3. Check wire harness connections to the dispenser motor and central control unit
4. Check dispenser motor for powered rotations
Hope this helps
Jul 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Showing F-30 error code
F30, indicate an electronic communication problem with the washer. Some Duet models are equipped with electronic displays that will read "F30" when this error occurs. Models without displays instead illuminate a given combination of LEDs to indicate an error. In the Duet Sport, for example, when the "Wash," "Rinse," "Spin" and "Cycle Complete" LEDs are are illuminated at the same time, an F30 error is present.
Other comments about this problem suggest "storing" detergents on the top cover. A new, full bottle of Tide caused problems for us. Cleared the top of it, problem solved.
I suggest visit and check this link: Use and Care Guide
Hope helps.
May 16, 2011 | Whirlpool Washing Machines
Whirlpool WFW9200SQA10 Front Load Washer displays F30 code. What does F30 mean? Thanks
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 20, 2010 | Whirlpool WFW9200S Front Load Washer
My Whirlpool washer flashed F30. Not filling up with water.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F30
The F30 code refers to a failure of the dispenser motor. The clicking you were hearing was probably the dispenser motor switch going on and off trying to activate the dispenser motor.
Here is the service manual.
https://secured.whirlpool.com/Servic...LE/8178558.pdf
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F30 error
Dispenser system error,make sure the dispenser is clean
Jan 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F30 error code on whirlpool front load washer ''Duet''
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
Nov 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Whirlpool LHW0050PQ Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
