Question about U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613)
Default username for 5461 maxg
I have a 5461 max g router and I'm trying to accessing to change some settings but I've forgotten what my username and password is. Actually, I take that back. I'm 99% sure I know what my password is but I can't seem to remember what my username is. Does this router come with a "default" username or something because I'm pretty sure when I set it up that I used a "default" username. I've tried the basic ones like "root", "admin", "default", and even just leaving it blank!
Thanks for any helps
    Scholar:
  • 89 Answers
Hello, The easiest way to correct it to reset router back to default. Reset hole/button on back need to be held in 10-15 seconds. 5 seconds or less and it will reboot router. Once it is reset to default use 192.168.1.1 for address and "admin" for password. Leave usename blank. After in settings these can be changed. Hope this helps.
Posted on Mar 27, 2008
Crack password online
Restoring a Netgear Router to Factory Default Settings
Symptoms:
Cannot access the NETGEAR router or access point web interface login screen, or
You have forgotten/lost the password to log into the NETGEAR router or access point (NOTE : This refers to the password required to access the devices administrative interface. If you have forgotten the password required to access the wireless network, you should refer to this article instead).
http://kb.netgear.com/app/answers/detail/a_id/9665/~/restoring-a-netgear-router-to-factory-default-settings
Sep 16, 2013 | NetGear Computers & Internet
Can't get a link when trying to turn a Netgear router WGR614v8 into access point with a xfinity SMCD3GNV as the host router.
Log in to your NETGEAR router by browsing to
http://www.routerlogin.net/ or http://www.routerlogin.com./
Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults.
however, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection.
Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and Clicking Apply.
If there is a small hole in the front or back of the router push a hair pin in to reset to factory settings.
May 20, 2013 | NetGear WGR614 Wireless Router
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Dec 21, 2011 | Linksys Wireless-G WRT54G Router
Hi i've forgotten the password i set for my router about 18 months ago, so i can access wifi on my ipod touch, i've tried to reset and restore to factory settings using the button on the back,...
Since you reset the router, the username and password were set back to its default values as well. For Netgear, the username and password is: Username = admin Password = password
Aug 29, 2011 | NetGear WNR2000 Wireless Router
I've forgotten my security password for the wireless and want to allow another computer access. as i'm not very technical is it difficult to reset andstart again?i don't want to be without the...
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and configure it again.
To reconfigure your LinkSys, connect a PC to one of it'sEthernet ports, load a web browser, and go to the URLhttp://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." While newer models, both the default username and the default password are set to "admin."
Once you go past the login screen, you should be able to reconfigure the LinkSys router.
Here are some of LinkSys Router models along with its Default usernames:
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys WRT54G, BEFW11S4: admin
Linksys Comcast routers: comcast
All other Linksys routers: {none}
Here are some of LinkSys Router models along with its Default passwords:
Linksys Comcast routers: 1234
Linksys BEFW11S4: {none}
All other Linksys routers: admin
For those [none] username/password entries listed above, no name or password is required. Just skip or press the Enter/Return key when prompted for those settings.
Jul 18, 2011 | Zyxel (91-004-361002) Wireless Router
I have linksys wireless router and am trying to get wi fi on a recently purchased Kindle but Have forgotten my Linksys password. Please help
Hi nancylousdol,
If you have forgotten your password you can reset the router to its factory state and setup a new password for it. Resetting the router will wiped out all changes that have been saved. To reset the router, look for the small hole at the back of it. Press and hold it for 10-15 seconds using a Pen or Paperclip. Then access the router settings page so that you can personalize the settings.
For you to access your router you need a working computer that is connected to the router and open a browser type 192.168.1.1 to he address bar and it will ask you for a username and password. The default username is "leave it blank" and the default password is admin.
Rate me if this helps so i can help others.
Thanks for using Fixya
Jan 28, 2011 | Linksys Wireless-G Broadband Router
I cant login to D-link-i have forgotten my password and i have tried 'admin' as username & 'password, admin' for the password and also tried leaving it blank, as well as the pin on the bottom of the...
The default D-link router login is admin with no password. With that said, you probably cannot login to your router because D-link requires you to change this default login the very first time you login to set it up. If you have a router you setup a long time ago and have forgotten its password and settings, you will likely have to reset D-link router password.
If you look at the back of your D-link router, you will see a pin-hole. Inside that hole is a button that resets the router. To perform the reset, insert the end of a paperclip in the hole and depress the button for about ten seconds. Leave the router on during this time. It will reboot by itself and the WAN light will begin flashing on the front.
When it stops, the router is reset and you can login to it using your web browser. Just type http://192.168.0.1 and click enter. You should see the D-link login window. Type admin without a password and you will be presented with the default d-link settings again. Configure a new password and wireless settings and your router will now be accessible again
Jan 27, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I changed my password but I forgot it
Do you have a Linksys router and you have forgotten your password or you want to reset the password to the default. Firstly you must have physical access to the router. This article is basically for WRT54g and model BEFW11S4
If you have changed the password from the default password and have forgotten the default or your router did not come with any documentation.
To regain access to the router try the following. In the username field leaveit blank and in the password field type admin
Username / leave blank
password / admin
The Rest Button on a Linksys Router
To reset the router
While the back of your router might look different, the reset button is usually clearly marked. To reset the router to the default password, insert something thin--like a pencil point--and depress the red button. Hold that for a few seconds. The password for your Linksys router should have reverted to its default.
Try accessing it from a machine that is plugged directly into it. The default address is usually http://192.168.1.1. When you gain access to the router then you can change the password to any word of your choice.
May 28, 2010 | Linksys Wireless-G WRT54G Router
Forgot my password
Most of the NETGEAR devices have the following default username and password except ReadyNAS products and Fully Managed switches:
  • Username is always admin
  • Password is password or (for older devices) 1234
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 26, 2009 | NetGear RangeMax WPN824 Router
Hi, I want to connect a PS3 to my wireless router but have forgotten the password?
If you have never actually set a password, go to eh IP Address 192.168.1.1 OR 192.168.2.1. The username field is blank and the password field is admin.
If you have actually forgotten the password, you need to reset the router. You can do this by gaining physical access to your router. There should be a reset button (or hole) in the back of it. You need a pin or something really skinny that is able to fit inside there. Hold the button for 20 or 30 seconds. After the router lights stop blinking about, the router is fully reset to factory details. Go to the IP Address 192.168.1.1, and the username and password is the same as above.
Dec 27, 2008 | Linksys Wireless-G Broadband Router
U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613) Logo
2,799 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Sunday Ojelabi
Sunday Ojelabi
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
