Question about Gateway FPD2275W LCD Monitor
Black screen When I turn on my computer the screen just comes up black...any suggestions BenQ FP71G 17 in. Flat Panel LCD Monitor
  • carlosrh Mar 29, 2008
    Dear Mergatroid: None of the solutions you gave me appear to work, and I appreciate your trying to help me.
    I have tried to solve this problem but I´m afraidI willhave to take my machine for service. It´s still under warranty.Anyhow, Thanks again but if you come out with another suggestion i´ll be happy to receiveit and try it,,, Have a nice weekend!!!!!
  • Anonymous Apr 24, 2008
    first thanks for help.
    my problem with T705 is when the windows startup its opend for a while and return to black screen and come back active when welcome screen of windows xp apear after moment its cameback to black screen againand stay at black screen. when i turn it off and on again its come active for secounds, and i see this message apears"nonperest mode !" and after that come to black screen and the power led is green.
    after many trying to on and off the T705 it come to active and working good
    and when switched off for 10 hours the problem come back again
    please help me to solve this problem
    note: am electronic engineer and know how to use the tools
    thanks
    best regards
  • 286 Answers
Does your computer appear to be booting?
Do you head any startup noises, or the startup sounds you hear when Windows loads?
In no, have your computer checked.
If yes, make sure your cables are all snug. Other than that, it depends on how into "fixing it yourself" you are.
Give this a try:
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad. Check the area for any cracked or overheated ceramic or mylar capacitors.
You'll need a soldering iron, solder, solder ****** and some idea of how soldering and desoldering work.
Posted on Mar 27, 2008
SOURCE:
Q7T4-fp71g BENQ monitor picture come and go.power on.thanks.
try it in another coputer if not work you need mantinace eng
Mar 25, 2011 | BenQ FP71G 17" LCD Monitor
My BENQ monitor blacks out
Use the remote to access menu mode
then try inputs through the remote
Jun 16, 2009 | BenQ FP71G 17" LCD Monitor
Benq FP71G words fuzzy with purple
Hi..there,
Don't bother...you've got a busted panel. If it still under warranty send it back for replacement of panel. If not, then just buy a new one... it's will saved you $$$...
Dec 06, 2008 | BenQ FP71G 17" LCD Monitor
BenQ LCD DV3250
Hi...there,
Well, have you try plugged into a different port like a DVI port. If you don't got one try replaced with another VGA cable.
Sep 26, 2008 | BenQ FP71G 17" LCD Monitor
Part of an LCD monitor became brighter than the other part
This should be a panel problem and maybe only solvable by replacement.
samir
Sep 01, 2008 | BenQ FP71G 17" LCD Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
BenQ FP71G+ screen blank
If front power led is on and No display ,Problem is with Inverter circuit.The post u descibe should help you determine with certainity that Inverter is the issue.
Samir
Apr 08, 2008 | BenQ FP71G 17" LCD Monitor
Black screen
Does the monitor's menu work? To test this, just start punching button's on the front of the monitor, and if the OSC comes up, then you know that the monitor is probably not the problem. Does you monitor have more than one input? If so, try switching them to see if you computer is outputting them. Also, try the monitor with another computer. Once you've tried this, let me know, and I will give you more suggestions if it still doesn't work.
Mar 15, 2008 | BenQ FP71G 17" LCD Monitor
Benq screen shuts down when pc is plugged in
If it's a 71g and not 71g+ resolder transistors 2sc5707 on invertor board along with grey condensers and inverter transformer.This should solve the problem if it was display shutting off with power led remaining on.Otherwise check power section.
Feb 24, 2008 | BenQ FP71G 17" LCD Monitor
Benq FP71G+S NOt starting.
Hello
I have had this problem twice once at my school and once with my BenQ FP71G Monitor. At my school the monitor ( HP ) just stopped working and smelt like burnt popcorn.(though is think this is due to some kids chucking a soccer(football) ball at it! With my BenQ it has the same problem though i nownthink it is because of the monitor has been on for excessive hours ( 3-4 ) and just shut down because of overheating. I will see in a couple of hours if it works !
Copper_R
Dec 30, 2007 | BenQ FP71G 17" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
129 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
