F68 occurs on these ranges when the power lines are not hooked up properly. Usually its a miswired cord or outlet. If you are using a 3 prong range cord, you need to check with a meter that you are getting 240 volts between the 2 outer terminals of the plug, and 120 volts between either of the outer terminals to the center plug. If you are using a 4 prong cord, the test is the same except you should also get 120 volts between either of the outer terminals and the flat center plug and the round center plug. Flat center is NEUTRAL, round center is GROUND. On a 3 prong plug, center terminal acts as NEUTRAL & GROUND.
If all of this checks ok, then its time to pull the cover off the back of the range where the cord goes in and make sure the wires are connected properly there. 3 wire cord should have the 2 outer wires going to the outer terminals on the terminal block and the center going to the center terminal. 4 wire cord should have black and red wires going to the outer terminal posts, the white goes to the middle post and the green goes to the frame.
If all of this checks OK then you need to have a COMPETENT electrician go over every part of this circuit, from the outlet to the breaker box, and make sure everything is connected properly and TIGHT. A loose NEUTRAL connection can cause all kinds of erratic behavior with electronic control ranges.
The fact that you've gone through 3 of these ranges should tell you it's not the range. Most likely it's something the electrician has overlooked. I've run service calls behind electricians that have bragged about their 30 years of experience, etc and think they know what they are doing but still don't understand how to diagnose problems like loose neutral connections.
Good luck. Reply back when you find out what it was!
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jeffrey_634abadf963e31e5
