Question about Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs
Scotsman cme 1056as-6f ice machine makes high pitch noise (as your car's old drive belt would) and shuts it self off. It's an air cooled system. Any idea?
  • 531 Answers
SOURCE: loud vibrating noise
may be screw left out
Posted on Apr 02, 2009
  • 102 Answers
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Posted on Aug 06, 2009
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
  • 33 Answers
SOURCE: Scotsman Ice Maker CME 256
descale bin level sensors, check for corrsion on wire harness. if does nt work. replace . bin level sensors
Posted on Aug 26, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Posted on Nov 05, 2009
Scotsman ice maker, short freeze code no ice
this Scotsman Prodigy had bad Ice thickness probe, error was for long freeze cycle. Hope this video will help someone
Jul 13, 2014 | Kitchen Appliances - Others
Scotsman sce275 making ice too thick
carefully adjust the ice bridge thickness screw at the top no more than 1/8 of a turn counterclockwise in between freeze cycle until desired thickness is obtained. clockwise gets thicker and counterclockwise thinner.
Apr 12, 2013 | Scotsman Ice Machine - 290lb...
Mv450 scotsman high pressure
Check to make sure the condenser coil is clean, fan motor is running during freeze cycle. High Ambient temp, Ventilation, The higher the temperature entering the condenser coil the higher the head pressure. Fan motor failure, pressure switch failure. The cut out pressure varies 400, 450 or 500 PSIG. Water supply failure. not enough water running over the evaporator plate will cause high presser.
Jul 30, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Hello, I am a Certified Athletic Trainer at a high school. I back mid summer break and found that someone had turned off and emptied the ice machine. I can't find my manual; is there anything I...
Download this manual. On pages 20&21 are cleaning instructions. Also install a water filter.
http://www.scotsman-ice.com/docs/uploaded/sct/manual/275m.pdf
Jul 12, 2011 | Scotsman Ice Machine - 290lb...
Scotsman has become very slow in making ice
I would try cleaning the unit, plus if there is a inline water filter I would replace it
May 23, 2010 | Scotsman Ice Machine - 290lb...
I have a Scotsman CME 1056R. Diagnostic water light is on
cut power to unit pick up water pump unil u see bottom of pump..try to spin manuely..chances are your pump is locked ..if spins freely ohm out motor windings..make sure ur getting power to pump
Sep 06, 2009 | Scotsman Cooled Modular Contour Cuber Air...
Banging noise in water line
If it is banging after it shuts off or cycles you may have a noisy compressor.It can happen during a move or if it droped.Hope i helped:)
May 18, 2009 | Scotsman Ice Maker WBin Flake Style water...
Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs Logo
43 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
