Question about Zenith Z32H41D TV
White Horizontal line across screen
I recently aquired a Zenith Z32H41D TV. The TV has a white horizontal line centered on the TV screen. Is this a common problem and does anyone know which faulty part is the most likely culprit? Any info would be greatly appreciated.
  • 23 Answers
It is most likely the vertical deflection IC has overheated and lost its soldering. If you open your TV up, it is a 10-15 pin in a row IC sticking out of the motherboard attached to a heatsink. It should be labeled "IC451." Give it a wiggle, see if it affects the picture, You may have to resolder them in place.
The IC may be hard to find, look for a peice of metal that is sticking out of the motherboard, attached to a small chip. I fixed a samsung tv that had it in the middle area.
Posted on May 12, 2009
No picture, Horizontal line center of screen
Can be a case of vertical collapse. If this is the case, then the vertical oscillator and/or the vertical driver circuit are faulty. .
You can take you problem directly to zenith. They have a customer service post available here
Mar 30, 2008 | Zenith Z32H41D TV
When I turn my TV on, I have sound but only a horizontal white/color line across the screen. My TV is an old Zenith 25" floor model.
You can buy a new one for less than 200 bucks. I'd advise you do this. It sounds like you need a new
picture tube
Dec 31, 2010 | Zenith C27A24T 27" TV
RCA-single horizontal white line
Your vertical deflection IC is bad.
Nov 04, 2008 | Televison & Video
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Televison & Video Logo
262 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
