Question about Canon PowerShot A75 Digital Camera
Can't get lens to retract = on off button does not seem to work- batteries are new and fine
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 07, 2010
I cannot retract the lens back to my Rollei 35 se
Your question seems to be mis-categorized under slide projectors, if you are asking about Rollei 35 SE camera, the lens will only retract if you cock the shutter with the wind lever, then press the button next to the shutter release and rotate the lens a few degrees.
Nov 13, 2013 | Rollei 66 Dual Slide Projector
Lens won't retract and camera won't start even with new batteries
There will be some bit of paper or dust blocking the movement of sensor .
You need to blow air to remove the dust .
It will work .
Oct 20, 2008 | Cameras
Batteries Dead and lens wont retract.. I just got
There are some cameras who give problem when they are new. Give it some time i am sure it when the battery is on the move it automatically repaired.
Aug 19, 2013 | Olympus SP-820UZ iHS Digital Camera, 14MP,...
The stupid thing won't power up anymore. I try and cut it on and the green light just flickers then goes off. it froze when the lens was out too which means its been stuck that way for a while. I didn't...
I found that cheap (new) batteries will not work in my camera. Duracell or Rayovac seem to work best.
I added 2 (new) cheaper batteries it took 1 picture the lenses would not retract and the battery light flickered. I found 2 new Durnacell and it works fine now. Hope this helps.
Oct 14, 2009 | Samsung S860 Digital Camera
Lens won't retract
You could try to gently pull the lens straight. If it's leaning to the right then pull the lens to the left. Don't use brute force but it's possible to realign the lens this way. If it works you'll hear a click and the lens will look straight. Switch on and see if it retracts. I'd only use this as a last resort because you can cause additional damage if it's overdone. It has sood success rate also
Sep 06, 2009 | Pentax Optio M20 7MP Digital Camera with...
Samsung L100 digital camera beep problem
If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work.
If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
Hope this advice helps!
Aug 04, 2009 | Samsung L100 Digital Camera
Hi
Either the fuse has blown or there is another problem with the main PCB or possibly the battery door indicator switch.
Open the battery door, by the memory card slot is a tiny switch; is the black tab for the switch still there or is it broken off and missing? Is it jammed down? Try holding the switch down with a pencil and press the power button... does it work?
If it doesnt seem to be the switch, it's probably the fuse. If you can solder well you can probably replace it yourself, and I will get the fuses tracked down and listed in the store so they are available to anyone who needs them.. they are cheap!
We are a digital camera repair business, if we can help please let us know! Good luck from Darntoothysam com
Thomas
Darntoothysam com
Oct 20, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
LENS PROBLEM
I've been trying all of these suggestions, finally lying the camera on it's back (lens up) I hit the power button while wiggling the lens. This WORKED!! The lens retracted properly and seems to work fine now.
Aug 31, 2008 | Kodak Easyshare M753 Digital Camera
Lens won't open and retract.
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 03, 2007 | Kodak EasyShare CX7530 Digital Camera
Lens wont retract, makes noises, error code on blue screen D:1E 1A
I posted the same problem on the 15th June and in the meantime I have been playing around with the camera. After holding the camera upside down and gently tapping the back of it, the lens decided to work and retract back into the camera. Not the most technical advice I know but it seemed to work.
Nov 18, 2006 | Olympus Camedia C-60 Zoom Digital Camera
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
