Broken kenmore washer
Drum doesnt spin on my newer kenmore stylemaster washer. appears that a gear or transfer type defferential is broken(can see broken plastic teeth)
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Is this a top loader or a front loader? Could you please post back with your model number as well? I think I know what the problem is, but need to make sure, so I'm not giving you the wrong advice..
I have a Kenmore style master model #4217013 but it stopped spinning last night. Please let me know what to do.
Posted on Apr 28, 2008
I have a Kenmore 90 Series washing machine Stylemaster 4217017. It quit spinning tonight. How do I fix it?
Possible that the belt or the drive or the spindle assembly is the suspect. Click this link for tips to reset: Drum Reset
Jan 19, 2013 | Kenmore Washing Machines
My Elite H3 washer has been making a loud knocking sound during spin cycle for awhile now. Recently the clothes have been coming out wet. Today the drum stopped all rotation. I took off the back and the...
it sounds like the spider gear is bad,this is usually from using to much detergent,you can check the shocks but it sounds like the gear is gone.you'll know when it's the gear,it's very loud in the spin cycle,unfortunitly the gear is around 4 to 5 hundred dollars and then there's the labor bill,most likely better off replacing the washer.check out this video and you'll hear the sound i'm talking about....... YouTube - Kenmore front load bearing 18 months and kaput!
Mar 21, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore 417.44102300 front load washer. Yesterday as it approached final spin the drum was spinning at top speed as it usually does and all of a sudden it was like something let go and it started...
Possibly a broken bracket we see this happen frequently, with this type of model the parts are kinda high for this repair, look at picture in bubble.could be the shocks I don't think so.fgonzalez278.png
Mar 10, 2011 | Kenmore 44102 Front Load Washer
My kenmore washer will not spin or agitate. It
i dont know what model this is, but hopefully its a belt type.un plugg unit, place on its side and check if belt is broken or slipping. if enclosed transmission type, it is a big repair.
Sep 04, 2009 | Washing Machines
Kenmore front load washer #44072 drum banging noise
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
May 27, 2009 | Kenmore 44072 Front Load Washer
Motor runs but drum doesnt spin
The belt may have broken, you must open the dryer case and check the belt. If broken, you'll see it laying on the bottom
May 18, 2009 | Kenmore Dryers
Type 111 filled with water and stopped
with the machine off, turn the cycle dial around 3x very harshly, then try it again. If it works normally now, you'll need a new cycle switch soon!
Mar 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does not spin
You must replace the direct drive coupling between the motor and transmission. About $30.00
Mar 10, 2009 | Kenmore Washing Machines
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
286 people viewed this question
Top Washing Machines Experts
