Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Refrigerator/freezer not cold as they should be
Unplugged and thawed for three days then plugged back in and worked great for a week. About a week later it was not real cold again???
  • GE Master
  • 1,606 Answers
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main
control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger
wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3
. Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1
end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min ,
look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red
glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a
shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat (
pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to
remove the inside rear wall of the freezer . The heater , is at the bottom of the coils ,
held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire
going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control
board , the temp of the coils , if they need defrosted , when they are thru defrosting .
This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the
coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to
also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front
of the drain , also with 2 white wires going to it , slid into a housing . This thermistor ,
is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off .
Posted on May 07, 2010
  • Christopher Kirby
    Christopher Kirby Nov 29, 2010
    I have the same problem as above., replaced both thermistors and 1 week later same problem. Is there something I'm missing?
    Craziekirb at gmail dot com
Model flsc23f6ds1 mfg 08 04 one day the light and the temp reading started flashing then it quit and thawed out . we unplugged it and left it unplugged for a few hours . we plugged it back in and in...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
Cold air not getting from Freezer to Fridge
I actually know nothing about refrigerators, but was able to fix the same exact problem where cold air was not getting to the fridge side of the side by side. The freezer was working just fine. I unplugged the fridge and freezer and tore all the shelving out to get behind a panel in the back of the inside of the freezer. There is a pass-through between the freezer and the refrigerator at the top back of the freezer on the side-by-side refrigerator. The passthrough was totally frozen over and blocking air from passing through and cooling the refrigerator side. I let it all de-thaw and then was able to pull the chunks of ice out, and all seems to be working great now. Be careful getting the ice chunks out as there are some controls there - it's probably best to just let it all thaw and melt by itself - which wouldn't require tearing all the shelving out. One could simply let the freezer dethaw for a day and then plug back in and both sides should work just fine.
Aug 15, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer Working Intermittently; Fridge not as cold as should be
the model number you sent didn't come up,i sounds like you could have an inefficient compressor or a freon leak.when you checked the compressor was the condenser fan motor running?this is what keeps the compressor cool also clean the condenser coil too.another thing is that if you have a timer on your machine it could be sticking,if you send the model number i can tell you where it is,also if you remove the back inside wall of the freezer,look at the evaporator coil,the frost on the coil should be the same over the whole coil,if it isn't you have a sealed system problem and will need to replace the machine.if things are cold in freezer but not cold enough this is what it sounds like,do this,open the freezer door,you should hear the fan blowing,if not the evap fan motor is bad or it could be in defrost,if you don't hear the fan blowing wait around a half hour and check it again, it could be in defrost mode so the fan won't turn on until it comes out of defrost,also like i said make sure the condenser fan motor is blowing and the condenser coil is clean,if everything checks good and the freezer is cold but not cold enough and the best thing to check is the ice cream get a new machine,you have a sealed system problem.let me know what you find and good luck
Jan 05, 2009 | Kenmore 65812
Freezes for 7 to 14 days then just quits!
hate to tell you but your compressor is going out on your freezer ,,, i'd look for another freezer.
Larry
Oct 28, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Refridgerator Not Cooling
If top is compleatly warm it is probley the fan motor, lot of failures on them. Replacement one will be a different looking motor. Verify motor is not turning, located in the back of the freezer in the top middle, behind small grill. Will see fan blade pointed up, should run whenever compressor is on.
Aug 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jun 03, 2008 | Frigidaire FRT18G4A Top Freezer...
Kenmore 596.75509400 bottom freezer
JH, did you notice if the freezer back panel was full of frost first time it started thawing? If so you may have a defrost problem. I've had 4 of these control boards (jazz boards) fail on this model in the last week. Behind the front grill, there should be a tech sheet that will show you how to run the componet tests at the control board. Part number for the board is 12002339. This board controls compressor, defrost, damper and fans. Catriver.
Aug 04, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer is very cold refrigerator is warm
you have a defrost problem. could be your defrost heater or your defrost thermastat or i belive yours is a newer one with the electroic defrost timer
Jul 02, 2007 | Maytag MSD 2655 HES 26 cu. ft....
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
376 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
