Question about Intel Motherboard
1 What are the POST ErrorBeepCodes-2 Key sequence to eneter SETUP
I have the 845EMAX Need to know ...
1 "what are the POST error beep codes"
2 Key sequence to enter SUETP
(doing a TAFE course)
    Genius:
  • 1,027 Answers
Do a google search on Bios Beep Codes for the first, and to enter the BIOS setup, most PCs use the DEL key during the self-test. Some others use the F2 key. Most detail that, on the bottom line of the display during the post sequence.
Posted on May 07, 2010
How can I get my computer out of safe mode?
With the machine unplugged from the wall remove the battery from the motherboard. Then with the machine still unplugged press the On button for 30 seconds to dissipate any remaining electrical charge on the motherboard. Then re-install the battery, plug the machine back into the wall and see if it will boot normally.
May 11, 2015 | Dell OptiPlex 330 Minitower Desktop...
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
How to skip bios setup
F2 is your BIOS Setup enter key?
As SOON as you press the Power On button, start tapping on the F2 key.
Tap in 2 second intervals.
You may hear beeps. These are Stuck Key Error code beeps. You know what they are now, so just ignore them.
The BIOS Setup screen goes by F-A-S-T. You have a very small window of opportunity. This is why you are tapping on the enter BIOS Setup key, as soon as you turn the laptop on.
In BIOS Setup there is an option to bypass the P.O.S.T screen.
For additional questions post in a Comment.
Regards,
joecoolvette
May 21, 2012 | Computers & Internet
Ibm 8215 beep codes
Here is a list of beep codes, this may help determine the problem wit your system.
1. Keyboard
2. System Board1-4-X Error detected in first 64 KB of RAM.1. Memory Module
2. System Board2-1-1, 2-1-21. Run Setup
2. System Board2-1-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-2-21. Video Adapter (if installed)
2. System Board2-2-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-3-X1. Memory Module
2. System Board2-4-X1. Run Setup
2. Memory Module
3. System Board3-1-X DMA register failed.1. System Board3-2-4 Keyboard controller failed.1. System Board
2. Keyboard3-3-4 Screen initialization failed.1. Video Adapter (if installed)
2. System Board
3. Display3-4-1 Screen retrace lest detected an error.1. Video Adapter (if installed)
2. System Board
3. Display3-4-2 POST is searching for video ROM.1. Video Adapter (if installed)
2. System Board41. Video Adapter (if installed)
2. System BoardAll other beep code sequences.1. System BoardOne long and one short beep during POST. Base 640 KB memory error or shadow RAM error.1. Memory Module
2. System BoardOne long beep and two or three short beeps during POST.(Video error)1. Video Adapter (if installed)
2. System BoardThree short beeps during POST.1. See "System board memory" on page 62.
2. System BoardContinuous beep.1. System BoardRepeating short beeps.1. Keyboard stuck key?
2. Keyboard Cable
3. System Board
Nov 29, 2011 | IBM ThinkCentre M52 8215 - P4 531 3 GHz...
My dv6-1247 cl when i turn on the power it beep 8 times and the screen does not come on help
Yu will need to determine which BIOS you have a see below
The computer beeps several times
If you hear several beeps from the PC speaker, it means that the computer failed its power-on self test (POST) because a problem was detected. The POST is a procedure that tests several components such as power, BIOS, CPU, memory, and video. Only if all those tests pass, the computer will then allow the operating system to load. But if one or more of these tests fail, beeps indicate a problem and the boot process is halted. These errors are a little more difficult to troubleshoot.
To diagnose the problem, listen to the beeps carefully and write down the sequence. Is it one long beep? Is it several short beeps? How many? Once you have the beep sequence documented, you need to find out what it means. What BIOS do you have? When you first turn on the PC, look at the top of the first screen to find out. Common BIOS types are Award, Phoenix, and AMI.
Award:
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beeps Most likely a RAM problemYou can find more detailed information about Award error messages on Award's web site.
Phoenix:
1-2-2 Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information 1-2-2-3 BIOS ROM Checksum 1-3-1-1 Test DRAM Refresh 1-3-1-3 Test Keyboard Controller 1-3-4-1 RAM Failure 1-3-4-3 RAM Failure 2-1-2-3 Check ROM Copyright Notice 2-2-3-1 Test for unexpected interrupts 1-3-4-3 RAM FailureYou can find more detailed information about Phoenix error messages on Phoenix's web site.
AMI:
1 beep Refresh failure 2 beeps Parity error 3 beeps Base 64K memory failure 4 beeps Timer not operational 5 beeps Processor error 6 beeps 8042 - gate A20 failure 7 beeps Processor exception interrupt error 8 beeps Display memory read/write failure 9 beeps ROM checksum error 10 beeps CMOS shutdown register read/write error 11 beeps Cache memory badYou can find more detailed information about AMI error messages on AMI's web site.
If you get beep errors, you should try to think what happened right before they started. Did you add a new piece of hardware? If so, it might be faulty or not installed right. Remove it, then try again. If everything is fine without the hardware, try to reinstall and configure the hardware again. If that does not help, try exchanging it and see if that corrects the problem. If the error persists, narrow it down systematically. Remove everything but the CPU, memory, keyboard, and video card, then boot again. Does the error still occur? If not, then add one piece of hardware and try again. Repeat until one new component causes the error and you now know who the culprit is. If yes, then reseat your CPU, memory and video card and try again. If the error still happens, try replacing the CPU, video card and memory one by one to see if one of them is the troublemaker. If that does not help, you could have a bad motherboard. Check the motherboard carefully for any signs of damage. Also check for shorts, a metallic object could have found its way onto the motherboard, or the motherboard is not installed correctly and touches the case somewhere.
Page 1: Computer boot problems
Page 2: This page
Page 3: System hanging after POST
Page 4: POST running OK but Windows not starting
Good luck
Please rate FIXYA
Thanks
Apr 02, 2011 | Computers & Internet
Beeps
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Dell webpc,,2 short beeps and keyboard error
i can help you with the Post-Code Beeps.
AMI Bios= 2 Beeps. Parity error In First 64k Ram. ( reseat Memory ) Post Failure 1 or more Of the Hardware test Have Failed.
IBM Bios= 2 short Beeps. Post Error ( Memory Possibility ) review screen for details.
AWARD Bios Codes = 2 Short Beeps. Any Non-Fatal Error. Enter CMOS setup to reset.
I,d go for Memory ( RAM ) But first enter bios setup Usually F2 Or Delete escape et,c. Reset to defaults, and see if that solves your Problem.
Mike @ Compurepair.
Mar 07, 2008 | Computers & Internet
Intel Motherboard Logo
75 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
