Question about Pioneer PL-990 Turntable
Pioneer pl 990
I just bought a used turntable. The plataform where you put the records does not turn. Upon further investigation (after taking the black rubber, and metal circular base, I found a black "belt" seems like a rubber band. I realize that I have to put this together to turn the turntable. Are there any diagrams on how to loop this rubber around the gears?
Thank you,
Felix
  • perplexed990 Mar 27, 2008
    My PL-990 platform does not turn either. I don't know what the black band around the platform is for. There is red tape that is holding it in place on the platform. Could this be the reason the platform does not turn?
    Genius:
  • 1,175 Answers
Remove any tape from the belt
That is the drive belt for the turntable .
It's not that hard to set up. Take the mat off the platter and wrap the belt around the underneath -slightly-less-diameter portion.
With a pointed end needle or something like it , put the tip between the belt and the platter portion it's wrapped against.
Pull the belt away from that( keeping the rest of the belt on the platter portion) and set it over the motor pulley. This is usually a small diameter brass spindle unit
Posted on May 05, 2008
Pioneer Pl990 turntable sounds awful.... I have a pioneer pl 990 record player connected to a pioneer amplifier and a sony CD player. when I play an LP, the sound is bass heavy and I can hardly hear t
When the turntable plays, do you get a howling bass heavy sound? Have you tried turning down the volume and bass? If that corrects the problem, you have what's known as Acoustic Feedback. Check to make sure the tonearm is properly set up first. If it is, please visit my website at Audioserviceclinic.com. You may contact me there. Thank you.
Dec 13, 2014 | Pioneer PL-990 Turntable
I just bought a pioneer pl-420 direct drive record player and when i hooked it up to my samsung home theater system via the aux ports in front but when i play records the sound is too low im have to turn...
If the player has a MD/MC pickup head, you need to use an input suitable for MD/MC
(Magneto Dynamic/Moving Coil). If that is not available, you need to buy a standalone
phono pre-amp (pre-amplifier with RIAA-correction curve). Like the TCC TC-400G/L.
Example: See HERE and some info HERE.
Oct 07, 2011 | Pioneer PL-990 Turntable
How can iget the belt back on my turntable pioneer pl 990
PUT IT ROUND THE PLATTER BASE FIRST,THEN LOOP A BIT OF STRING ROUND THE BELT LONG ENOUGH, SO WHEN YOU PUT THE PLATTER BACK ON,YOU CAN LIFT IT UP A LITTLE BIT WHERE THE MOTOR WHEEL IS THAT TURNS THE BELT, PULL THE STRING TOWARDS IT SO THE BELT GOES OVER IT.DROP THE PLATTER THEN PULL THE STRING OUT.
Mar 31, 2011 | Pioneer PL-990 Turntable
Re. pioneer pl 990 turntable can the lid be closed
No you cannot play while lid is closed and YES you need an amp/receiver amp
Feb 28, 2011 | Pioneer PL-990 Turntable
Converting a turntable from automatic to manual
I suppose the only way to do it would be to stop it functioning completely. The only way would be to dissasemble the auto function. What you would need to do is work out which parts are essential for the turntable operation and which only activate the return. So you need to whatch the mechanism working. You will need to remove the base and look at from underneath, just like going underneath a car!
I can't say for certain if you can do it, only you will be able to determine it can be removed without affecting the operation of the entire turntable.
May 21, 2010 | Pioneer PL-990 Turntable
Motor turns feebly, not enough to make the platter
Sounds like the motor is bad if you say it turns feebly. See if you can turn the drive shaft with your fingers easily. If you find it hard, it's possible that something might have worn out. You could try oil in that case.
Feb 02, 2010 | Pioneer PL-990 Turntable
I need to reattach the belt under the table
Download the manual free at http://www.nodevice.com/user_manual/pioneer/other_home_component/pl-990.html
There are instructions there and pictures showing how to attach the belt.
May 21, 2009 | Pioneer PL-990 Turntable
Pioneer pl 990 turntable
Lift off the platter mat, then lift off the platter from the spindle - gently.
Underneath the platter is a sub-platter around which you place the belt - it should be held there by the stretch of the belt while you turn the platter back up the right way and place it back on the spindle.
Turning the platter by hand, you should see a small pulley come into view through one of the holes in the platter. You then stretch the belt slightly so that it slides over the pulley. Take care not to twist the belt while doing this.
Jan 10, 2009 | Pioneer PL-990 Turntable
Trouble with sound
Confirm that the stylus you bought is spec'd out for that turntable
Also check all four wires to the cartridge
Mar 13, 2008 | Pioneer PL-990 Turntable
Pioneer PL-990 Turntable Logo
654 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
