Question about Sony Bravia KDL-40S4100 40 in. LCD TV
My Sony Bravia get a wide (about a foot) line up and down my screen. It goes off an on when it wants to. It picks up background colors and it stays like that for a while. What can I do?
  • alejandrasul May 08, 2010
    How do I send you the picture I have it now.
  • 178 Answers
I don't know what does your mean by "line up and down my screen", if the line goes up from the bottom to reach the top of screen then goes back down to the bottom cycles, that symptom I have never seen. But if the line goes off and on, very high probability is the panel defective (see the picture, the ICs inside the panel loose, shall cause the Vertical or horizontal dead pixel lines). It is the most serious issue on the flat panel TV. Because the manufactory sells the panels, price even excess the TV.
If you need more accurate diagnose, you can post a picture.
Posted on May 07, 2010
  • Shukai Fung
    Shukai Fung May 08, 2010
    I can post the picture here, I don't know if I am allowed to show my Email address here.
  • 4 Answers
Wanna sell the tv for parts? Kev0201@yahoo
Posted on Feb 07, 2012
32 inch sony bravia EX400 showing distorted colors and red screen on start up
reconnect the cable that goes from main board to tcon.. if this dose not work out change the tcon board which is cheap arond 25 US dollors..
Mar 29, 2012 | Sony Televison & Video
I have purchased Sony Bravia LCD BX 42, which has a very thin horizontal line across the screen, how to fix the problem
my sony bravia BX42 has a color green horizontal line and it makes bigger and bigger until some color pink was appeared then I am worried if it will not turn to normal as it goes :(
Aug 29, 2011 | Sony BRAVIA KDL52XBR2 Television
Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Dec 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Line thru screen
The LCD Panel must be replaced to fix both problems. The cost in doing this would exceed the value of the set. I recommend not putting the money into it.
Skyassoc
Nov 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
MY TV WONT STAY ON WIDE MODE. wHEN THE ADVERTS COME ON IT CHANGES BACK TO HALF SIZE. I HAVE A NEW SONY BRAVIA
This is actually due to the signal format being sent down from the transmitters/broadcaster. They by defauly output 4:3 which your tuner in your TV interprets and rejigs it into 16:9. Te adverts as they come on are seen by the tuner in your tv as a change in aspect ratio, and therefore your TV is trying to best display these. However, if you go to your screen settings, you can change the screen auto format to your choice and this chould ensure that the picture always gets set to your choice. If set on default, it will vary between 'wide' and 'smart'.
Jun 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Horizontal lines in sony Bravia 26"
You need to replace IC8C01 and IC8C02 part# STK394-250. They are located on the main board (in the middle of the chassis) and are mounted on a large aluminum heat sink.
Jun 08, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Noticeable line through screen picture sony KDL-40V3000
TRY USING THE COLOR CONVERSION OPTION ,,ITLL FIX THE COLOR
Mar 07, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
575 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
