Question about KitchenAid Dishwashers
We replaced the pump in our dishwasher and it has the clean button flashing and wont turn on the machine
    President:
  • 949 Answers
The clean light flashes if the water is not heating properly or the control thinks it is not heating properly. Here is a link to some instructions I put together on what to look for and how to reset it so you can use it. Since you replaced the pump recently I would look for a wire that came off to the heater or temperature sensor.
Let me know if you have questions or if this works for you.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Posted on May 07, 2010
My dishwasher is not working
sounds like your drain pump may be blocked.
check to see if waste drainpipe is blocked,
if not try and see if your can get machine to drain into a bucket.
if not drain pump may have something blocking it internally if machine has a filter clean it out, if no filter remove drain pump a clean it out or replace if faulty.
i
May 23, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
My Bosch Exxcel dishwasher wont clean properly?
the cleaning section is mostly from the circulation pump. is the pump is not working it has to be replaced .go to sears partsdirect.com and check out part first,. this will let you know the prices to fix or replace. then call ten repair person and find the cost to change the circulation pump.
Mar 13, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
4 flashes and beeping
4 flashes indicates a drain failure. Could be obstruction in drain system-first check drainhose for kinks, check where drain hose attaches to wastepipe spigot for blockage. If OK blockage may be in pump- disconnect from power, remove bottom panels to access under machine. Drain pump located front left- remove plug from pump, then there is a plastic tag on top of pump you must push down, then drain pump will turn and come off (it comes off easily if tag pressed correctly, so don't force it!!)
If pump OK, fault will be with water indicator switch-sometimes get full of muck. Open dishwasher door, remove filters and clean out any water from base. Right in the bottom right hand side of sump you will see a round black grill- this is water level indicator switch. If it looks blocked up, advise replacing (you can try cleaning, but replacing is best). To replace, access from under machine-again, this switch turns and pulls out, but can be quite difficult due to it being located behind the heating tube.
So, check hoses and pump, then press and hold start button for 3 seconds- this clears fault and resets machine. Try another cycle-if OK, problem solved. Recommend expert assistence to replace water indicator switch.
Aug 04, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Dishwasher not responsive, just a blinking CLEAN light.
HI, this is a control fault that is located in the logic sector of the circuit board. You will need to replace the control in order to restore proper function.
May 30, 2009 | Kenmore Dishwashers
Ariston Dishwasher LI 675 DUO
1) Ensure the dishwasher is turned off.
2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher)
3) Pour powder indo the dishwasher
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
5) Press the on/power button on the dishwasher, so that it now turned on (a light will display)
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position
Sep 16, 2008 | Ariston Technologies LI640S Dishwasher
Whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
Apr 02, 2007 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
