Question about Fujitsu LifeBook P1120 Tablet PC
TRYING TO CONNECT WIRELESSLY TO THE INTERNET DOESNT WORK
Hey
I just got a used fujitsu lifebook and i am really pleased with the performance etc. i can connect to the internet using cables but wirelessly i have trouble.the wireless progeram is called intersil prism and its very confusing.
there is a boingo program that shows available signals including my own but boingo said you can only connect to boingo hotspots with it.
peace
Tamerlane
  • nityananda8 Mar 27, 2008
    sorry for not mention i am using windows 2000...can you give me the apropriate steps to take with windows 2000???
    Thanks for your help
    Tam
    when i try to run this program it says "component wmp dll or one of its dependancies not correctly registered a file is missing or invalid
    thanks for your help though any other ideas
    peace
    Tamerlane
  • 871 Answers
Wow! thats a very nice wifi card. prism.
anyway, here is a link for your windows 2000.
this connects you to any wifi hotspot other than boingo.
cheers
Posted on Mar 27, 2008
  • 22 Answers
Hi, If your using windows XP OS.
There is an easier was to manage your wireless card, instead of using the build-in wifi utility.
try this steps:
1. make sure the WZC (wireless zero configuration is enabled)
if not, you can enable it by click on the start then go to run and type
services.msc, to open the services local window.
then look for wireless zero configuration, right click on that wzc and enable it. (you can also enable that by selecting the properties).
on the status of wzc is "started", go to step 2
2. go to properties of your wireless network connection and select wireless network tab.
3. put a check mark on the option that said use windows to configure my wireless network setting and then click ok all the way out.
by doing that your wifi card should pick up any available wireless network around.
Note: wireless network connection icon can be access by going thru control panel >> network connection.
I have windows xp,sp3 on a Siemens Fujitsu Lifebook T4010D. First of all, the tablet and the pen didn't work after installing the OS, also with all drivers installed. A few days ago, when xp was...
All of these drivers must be loaded;
LifeBook T4010D Driver Name Version Size (bytes) Audio V 6.14.1.3916 1,926,959 ACPI Device Driver V.1.21 9,437ACPI_Ext Device Driver (For model with Integrated Bluetooth) V.1.0 8,365 Bluetooth Device Driver (For model with Integrated Bluetooth) V.3.01.03F 15,615,696 Chipset V.4.30.1006 2,374,963 Fujitsu HotKey Utility V.2.30 1,119,189 Fujitsu Button Driver V.1.1.0126.2004 273,237 Fujitsu Button Utility V.1.0.0825.2004 976,478 Intellisonic V.2.0.1 4,077,455 LAN V.7.84.0.0 154,167 Modem V.2.1.41 883,675 MultiMedia Bay V.1.0.7.4 4,964,535 Radio Control (For model with Integrated Bluetooth) V.1.0 853,561 Smart Card Slot V.2.7.3.2 3,110,839 Security Panel Application V.1.2 3,653,534 TouchPad Mouse V.5.4.402.9 1,928,173 Touch Panel Driver V.1.03 22,505 TPM (For Model with Integrated Trusted Platform Module) V.1.7 17,542,125 Video V.6.14.10.3741 7,234,518 Wireless LAN Atheros (For 802.11a/b/g) V.3.1.2.21 3,980,525 Wireless LAN Atheros (For 802.11b) V.3.1.2.13
Jun 13, 2017 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
My fujitsu lifebook t4215 will not connect to the internet. When I check the connection, it says that it is connected, but when I try to bring up Internet pages, it won't bring any up.
So you're connecting with WiFi eh? I take it you've already disconnected and reconnected with no progress?
Next would be to shut it down, and reboot. Try it again.
Are you connecting through a router? You might be "connected" to the router/hub but it may not be actually connected to the internet. Can anything else you have or someone else connect to the internet through the same connection? If so then we know the connection is good, and it's the Lifebook.
Look for "NETWORK AND SHARING CENTER" and see what that looks like. It should show you a graphic of the connection and you may find it as I described above. You need to eliminate or identify your condition at this point.
Good luck!!!
8^)
Jan 04, 2011 | Fujitsu LifeBook T4215 Tablet PC
Fujitsu Lifebook P1120 Won't Boot To CD\DVD
Fujitsu seems to have secretly added a Hardware black list for Booting USB DVD-rw.CD-rw drives.
I have a Stylistic ST5032D slate.
Your either going to have to buy fujitsu's over priced external drive or buy fujitsu's over priced dock.
Or What I do is Bought WinImage or any other software that allows writing a ISO image to USB flash drive, this should almost always work.
I had to install Windows 7 on my tablet this way.
Choose your poison.
Good Luck.
Oct 03, 2009 | Fujitsu LifeBook P1120 Tablet PC
How do i restore to factory without any restore diskson a lifebook t4010"
It is not possible to restore to factory setting without the accompanying restore disks. You can attempt to contact Fujitsu Siemens and obtain a set of repair disks from them.
Your only other option is to obtain a retail copy of Windows and perform a new installation, then download the required drivers from the Fujitsu Siemens web site.
Apr 11, 2009 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Resetting Security Panel Password
Its by virus problem. scan your computer by antivirus with update then try again.
Sep 20, 2008 | Fujitsu LifeBook T4220 Tablet PC
Lifebook P1510D network connection
i had the same problem, i had to install the updates on the "drivers and applications restore cd".  however that didnt work. so i had to download the 1.030 driver from the fujitsu web site.  this worked. but when i tried to calibrate the tablet i was not able to get it aligned.
there used to be 2 different programs for updating the tablet, but now i cannot find the other one.
Dec 17, 2007 | Fujitsu LIFEBOOK P1510D Tablet PC
Writing pad prob lem
but did you formated all by you? did you already installed drivers for those that don t work? usualy those drivers are not inside xp SO so you would need to install it using support download
Aug 21, 2007 | Fujitsu Siemens LifeBook T3010 Tablet PC
Fujitsu LifeBook P1120 Tablet PC Logo
1,296 people viewed this question
Top Fujitsu Tablets & eReaders Experts
Tony
Mohammad Abumuailek
Mohammad Abumuailek
Computer Links
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
