Question about RTO Allis Chalmers W,wc,wd,wf,wd45 Tractor Complete Gasket
Recently had starter rebuilt. trying to get tractor to start. only used a few times when trying to start engine. Didn't overheat starter. Today, it turned over engine well in 2 attempts. On the 3rd attempt, starter didn't even try to turn over...no sound, etc. Battery tests strong and normal. I took starter out and can rotate shaft with strong effort. Why doesn't the starter work?
The solonoid could be bad causing the problem. also be sure the starter wires aren't loose as this can overheat the starter.
Posted on Jun 05, 2013
    Problem Solver:
  • 16 Answers
You said that you had the starter rebuilt, is there a chance that somethng was misaligned when it was reassembled? Also were the brushes replaced?
Posted on May 07, 2010
Engine won't turn. Have checked battery, starter, solenoid
The float needle in the carburetor is not closing which will allow gas to keep filling up into the cylinder and compression is blowing it up to the air filter.
There could be dirt or a build up ring around the needle of a jelly like material from sitting through the winter or just a build up over a long time
Cleaning the float needle may work but a new one is better
Dec 27, 2013 | Garden
Craftsman dt4000 starter problem
if it's an overhead valve engine( OVH) the valvevs have to be adjusted
periodicly.the smoke may not be actually coming from the starter.
The same thing happened to me. And, It's muck better to take it to a
small engine repair shop for that adjustment.
Sep 25, 2012 | Garden
Today I went to turn on my car and it didn't crank
make sure the starter is tight and your battery cables are clean and tight if automatic try putting it in neutral if it starts you may have a bad neutral safety switch if it is a stick try push starting if it starts you may have a bad clutch switch also check for a starter relay if u have one try swaping with horn relay and see if it starts
Mar 25, 2012 | 1993 Ford Probe
1997 VW Jetta GLX Had problems with the car starting. Hear nothing, no sound from the engine at all. Replaced the starter recently. Had some success with starting the car, however; Jetta seems to not...
Behing the ignition barel you have contact plate with plug.Change it.There is special tools to remove the wheel sreering column bush.Go to VW garage.
Jun 14, 2011 | Volkswagen Jetta Cars & Trucks
What does the hour meter on my mower actually tell me? It is flashing between hours of usage and chg oil. I changed oil and filter about four running hours ago. I cut grass for a few hours and then...
Hi, the meter flashes oil change when they are due(at pre-programed intervals) and will stop flashing two running hours after flashing starts. The hours that are showing are total running hours from new. Hope this helps, regards Phil.
May 31, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a YTH2448 Tractor that overheats
Although blockages in the shroud and cooling fins are the most common cause of overheating, a small gas engine can also overheat if the fuel-air mix is too lean. Are you sure the carb overhaul kit had the right parts, and is there any possible of adjusting the mixture? Here is a set of parts diagrams for your tractor - Engine-2 has the carburetor-related parts. Good luck!
Jul 25, 2010 | Husqvarna Zero Turn Mower Z5426
My 1995 lexus has recently not started after
do you hear the starter click or try to turn the engine. Most likely it is your starter. The contactors wear over the time/the number of starts over the years. You can get a rebuilt starter or buy a new one. If you are up to the challenge you can but repair kits to rebuilt it. It a 300-400 dollar job at the dealer.
May 24, 2010 | 1995 Lexus LS 400
Garden tractor, starter motor does not crank
Your starter may need to be rebuilt or replaced.
Apr 04, 2009 | Garden
MY MOWER WANT START
probably a bad starter hit it on on end with something a hammer or rod a few time and try to start it right away. if that works its a bad starter needs replacing
Feb 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Starting problems
if this problem persists then you could check a few things on it, like on the times when its not even making a noise when trying to turn the key, use rubber/wooden object and tap the starter motor but not touching the contacts on the back. if this amkes it spring into life then it will be your starter motor if this does nothing then it will be a dodgy battery supply. does it also make like a screaching noise while trying to start? if so then definitely your starter motor
Feb 25, 2009 | 1998 Honda Civic
RTO Allis Chalmers W,wc,wd,wf,wd45 Tractor Complete Gasket Logo
129 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
