Question about Kenmore 72062 Gas Dryer
How do you remove the front of the kenmore 80 gas dryer
I need to replace the gas valve coils but can't find where they're at
    President:
  • 512 Answers
You need to remove the panel at the top, then you remove the top, then the front, screws for front are inside of dryer. Go to www.appliancepartspros.com and put in your brand and model number. It will pull up all parts for your dryer including schematics that you can enlarge and print of the whole breakdown of you dryer. This will really help you to take apart and put together. Gas coils are at bottom under drum.
Posted on May 08, 2010
2 Suggested Answers
SearsTechToo
  • 261 Answers
SOURCE: Kenmore Serios 80 Gas Dryer - Replacing Gas Valve Coils
I haven't done coils in a while, You will need to remove the top and front panel to access the coils. The top should have catches that allow you to grasp the top by the back corners and pull forward slightly releasing the catch for left an right sides, other will have to have the top console removed to reveal 3 hex screw to pull the top off. Once done get a 5/16 and remove two hex screws left and right on the inside edges holding the front on, also unplug the harness to the door switch, by now the machine should be unplugged. the coils have a flange over them held on by some phillip screws. the orifice is preset so dont mess with adjustments, they should pop out and pop in
Posted on Sep 15, 2008
I have an 80 series kenmore gas dryer, will not heat, is it the starter? where can i get one, is it an easy fix? don
it could be the glowbar that ignites the gas,or it could be the thermal fuse in the dryer vent housing,the radiant sensor on the burner tube box that detects the flame and keeps the gas valve open,or the gas valve boost and secondary coils on the gas valve are open or weak and can't keep the valve open any longer,you need to remove the front cover and top cover to remove the drum to check any or all of these components
Jun 17, 2010 | Kenmore 63942 Dryer
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Kennmore 80 series dryer.ignitor glows red i hear a click and it goes out motor runs/no heat
Hi, You will need to replace the coils on top of the gas valve. Here is how on most models. If this does not apply to you model, get me a model # and I can look UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
this up for you.
Jul 09, 2009 | Kenmore 63942 Dryer
Kenmore 80 series, flame goes off after a few minutes later. igenitor trys to relight but dose not
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks
Jun 26, 2009 | Kenmore 74602 Gas Dryer
Kenmore 80 Series gas dryer starts with heat but very short time
Jun 23, 2009 | Kenmore Dryers
Gas dryer will not heat up kenmore 80 series heavy duty 72822
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, both are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Jun 21, 2009 | Kenmore 72822Gas Dryer
Kenmore 80 series gas dryer w/ no heat
Hello Friend, Your problem is very simple to fix. You're dryer needs a thermal fuse and or gas valve coils, and maybe an igniter all three are very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Now, if this don't solve the problem you will need a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new, if it doesn't then you will need to check the igniter. The igniter is attached to the end of the burner assymbly by one screw and a simple two wire plug. Inspect for breakage, and replace if needed. Happy to help, Tim.
Jun 15, 2009 | Kenmore 72062 Gas Dryer
Kenmore series 80 gas dryer will not heat up
Hi. this dryer has a set of coils that sit on top of the actual gas valve assembly. these coils activate the main and secondary gas valves and if the coil assembly is malfunctioning or, the wires and clips are corroded, the coils will not activate the gas valves to open and close. this malfunction will affect the heating process within this dryer unit.
I recommend inspecting the dryer coil assembly. use a mulitimeter to test for Resistance. you should get a reading of some type of current flow through the wires and, if this is the case, the coils are bad and they will need to be replaced.
This test is actually not needed. the non existing heat is a red flag on its own and, it greatly confirms a major failure within the coil assembly. replacing the coils will fix your dryer.
PLease rate and god bless:)
Apr 20, 2009 | Kenmore Dryers
Sep 07, 2008 | Kenmore 72802 Gas Dryer
Kenmore 72062 Gas Dryer Logo
67 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
