Question about ViewSonic VX1940w LCD Monitor
I have View Sonic VX1940w LCD few days ago i face a problem 1. with DVI cable when i turn On the system then at the boot up this LCD show Green display with black dots and some time at long in window of XP it reduce and work fine 2. Some time when i start my computer then with Green and Black dots(DVI cable) after that display just turn in to BLACK and no responce even Power Light still shows the DVI singnal indication 3. Now i Attach Standard 11 pin Cable first time and this monitor work fine i dont know what to do ..... Is there any software available that atleast troubleshoot the problem or i know what exectly problem is ???? thanks
SOURCE: ViewSonic VA912b (Back light with blank dark screen)!
I have the same problem. If the computer goes into power save mode for the monitor the VA912b won't come back on. The LED blinks and it makes a repeating "bloop" noise.
I have no solution other then what was stated. Turn it off for several minutes and turn it back on. Sometimes you have to try this repeatedly before it works. (I have two VA912b monitors that I bought at the same time and both are connected to the same pc - this only happens to one of them)
Posted on Feb 14, 2008
  • 180 Answers
SOURCE: with dvi monitor goes black for 2 second then comes back intermittently
To what I understand. Dvi and vga is only applicable to a system or CPU. Sorry if I am wrong.
Posted on Apr 17, 2008
  • 3085 Answers
SOURCE: ViewSonic LCD Monitor Went Blank
It is probably a bad INVERTER and / or backlight fluorescent bulb.
Posted on Jul 02, 2009
SOURCE: LCD monitor turns black after a few seconds
I went through a lot of threads trying to come up with the solution to this problem, monitor goes off after a couple of seconds of just hitting the blue power button, and the solution I came to is the power supply within the monitor has gone out! which is common for flat pannel monitors, but I am not saying my situation is the same as yours, if you see different colors when it goes off on you, their is other problems wrong, mine has always been the power supply and I just take the monitor to a laptop repair guy and he charges me 65 flat to repair the issue. instead of going to viewsonic which they want you to send them and pay out of pocket first before they fix your issue. I will say 65 dollars flat and 3 days of not having a monitor is better then going to the ups store and paying 65 to box it and 70 to ship it. I guess look around for an electronics expert in your area and have them take a look at it.
Posted on Nov 15, 2009
  • 11361 Answers
SOURCE: Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps):
Post back what you see so we can help you further.
Posted on Feb 06, 2010
Why does viewsonic monitor vx1940w dvi goes to sleep on windows 7?
Make sure the resolution signal sent out via the DVI is a valid timing signal the monitor can recognize.
May 20, 2014 | ViewSonic VX1940w LCD Monitor
I have view sonic VA1912WB 19'' black lcd monitor.. recently im acing problem with it..after i turn on the system the green light blinks and there is no display on screen.. after several(5-6)...
try another monitor on your system if you can barrow one somewhere to eliminate that it may be the computer... if it is the screen check the warranty on it at the view sonic web site... also check the cable from the comp to the screen to see if it is lose. try another cable or if it has hdmi dsub or dvi try those types as well. it may have a lose connector on the one your using...
May 20, 2011 | ViewSonic VA1912wb 19" LCD Monitor
My screen shows start up screens but while my computer loads, i cannot view my window screen... it became black but however the power button is still green
Welcome to FixYa!
here is the things you should do .
1. download a drivers click here
2. Restart the system in safe mode and install drivers (these are up-to date)
3. Check the LCD have you plugged the DVI cable or simple VGA cable ..
3A. And if are you using any Graphic cards remove the DVI cable just use motherboard's own VGA
outlet and connect it to the LCD , if it works then you might have the problem with graphic card,.
4. Check either your LCD is displayed on 1 or 2 check the button near power button on LCD.
If it does or doesn't solve your problem do comment here ill know.
Best Regards
Apr 13, 2011 | ViewSonic Pro VP2130b 21.3" LCD Monitor
Viewsonic VX1940w monitor comes on for a few seconds then turns off. Press the on/off button and then turn it on again, monitors only stays on for a few seconds then turns off.
vmesa, Do not feel alone! Your monitor's problem same as ten thousand other CCFL back-lit LCD monitors all over planet earth!!!! Yes, and I mean the exact same symptom as you have stated. Yes, it can be fixed, but you shouldn't look to software or drivers to do it. Read my and other monitor guru's FIXYA profiles to find out if you have what it takes to attempt DIY repair on your unit!!! Follow all links you find and visit YOUTUBE!!! After an hour or two of reading you will understand your monitor and what might be the real cause for it's Black or Blank n Black screen symptom and how to fix it. If your pocket is deep enough, then skip all the reading and use VX1940w for trade-in on new unit. 12fixlouie
Bye for now.
Feb 19, 2010 | ViewSonic VX1940w LCD Monitor
I use this monitor mostly for computer and yesterday when I turned it on everything had a green tint to it
Make sure the connections are tight. Are you using DVI connections or Analog?
Also, make sure your video care is properly seated on the motherboard.
May 28, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Some green color patch in the middle of the screen
Looks like you have an LCD. I was guessing it may be magnetic related in which case I would recommend you degaussed your display using the degauss function but your monitor won't have it since it's not a CRT by the looks of it. I would recommend contacting your dealer or where you purchased the monitor at a retail store. Since it's only 8 months old, you may be able to return it under warranty. If your retail store doesn't let you do that, talk to View Sonic directly and see if you can RMA your product for returning to the manufacturer and receiving a new or repaired unit.
Check out Viewsonic's website for more information.
Mar 24, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
No signal from computer to monitor 8/13/08!
I had the exact same problem!! Drove me crazy for days. Couldn't find any answers online, contacted Gateway tech support and they told me my warranty was expired but they'd be happy to discuss my issue for $2 per minute. Gateway can **** it!!
At first I thought the problem might be a malfunctioning NVIDIA card, a problem with my DVI cable, or the monitor itself. But, after turning off the computer, unplugging the DVI cable, replugging the DVI cable and restarting the computer, I noticed I could get the firmware flash screen to show, including the BIOS menu boot and the Gateway system reinstall screen to show. As soon as the Windows flash logo would display, however, the monitor would drop out and display the dreaded "No Signal" error.
This indicated the problem was a software one and not hardware! The cable, monitor and video card were all working fine. Then I remembered that Windows installed its automatic update a few days prior. In fact...
After succesfully booting into safe mode (F8 during the flash/bootup screens), I went to Add or Remove programs in the control panel, clicked on the "Show Updates" box on the top, and uninstalled the Windows update from a few days prior to the occurance of the error. After a reboot the problem was solved.
I hope this will help anybody else struggling with this error!
Aug 15, 2008 | Gateway FPD2185W 21 in. LCD Television
ViewSonic VX1940w LCD Monitor Logo
83 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
